93 computer module
Old Oct 22, 2005 | 04:18 PM
my93's Avatar
my93
93 computer module
93 F150, 302,FI, auto, 2wd
When the battery is disconnected and reconnect is there a timeframe before you turn the ignition on to start the engine to reset the computer back correctly. Seems after I disconnected and reconnected the battery the engine is not idling as fast and believe the power loss effected the comupter module memory.
Also what is invovled to remove and replace the steering spindle top bushing?
Thanks
Old Oct 22, 2005 | 05:11 PM
Ponyracer's Avatar
Ponyracer
after disconnecting the battery, the computer (PCM) needs a series of drive cycles to learn driving strategies again. So until it has these drive cycles, the computer is in what is called learning strategies which could change the way the drivetrain drives and acts.
As for the spindle, someone with experience on that will post here soon.
Old Oct 22, 2005 | 06:46 PM
frederic's Avatar
frederic
let the truck idle for a few minutes, rev it once in neutral, then take it for a ride to a highway and open it up and accelerate hard.
The computer has relearned enough that it will run fine going forward, fine tuning along the way.
It really doesn't take zillions of miles for the computer to relearn the hardware.
The top bearing in the steering column is removed like most bearings - a bearing puller. If it's really warn, it might even fall out. Mine did when I replaced it 2 years ago. I turned the column upside down and it fell out.
Old Oct 22, 2005 | 07:49 PM
my93's Avatar
my93
Thanks. Regarding the bushing, I'm speaking of the one at the upper top of the wheel spindle directly above the lower ball joint. I now have play in that joint. Thanks
Old Oct 22, 2005 | 09:49 PM
Ponyracer's Avatar
Ponyracer
sounds like the upper ball joint. They are upper and lower on the knuckle assembly.
.................................................. .....upper balljoint
this being the knuckle end------>[
.................................................. .....lower balljoint
Old Oct 23, 2005 | 06:52 AM
subford's Avatar
subford
Wheel Spindle, F-150, F-250, F-350 4x2
Removal
1. Raise the front of the vehicle and install safety stands.
2. Remove the wheel and tire assembly.
3. Remove the disc brake caliper (2B120) from the rotor and wire it out of the way.
4. Remove the dust cap, cotter pin, nut retainer, nut, washer, and front wheel bearing (1216).
5. Remove the rotor from the front wheel spindle (3105).
6. Remove bearing cone and roller (1201) and wheel hub grease seal (1190). Discard the seal.
7. Remove front disc brake rotor shield (2K004).
8. Disconnect the steering linkage from the integral front wheel spindle and spindle arm by removing the cotter pin and nut and then removing the front wheel spindle tie rod from the spindle arm with Tie Rod End Remover TOOL-3290-D or equivalent.
9. Remove the cotter pin and castellated nut from the lower ball joint stud.
10. Remove the nut from the axle clamp bolt and remove the bolt from the axle.
11. Remove the camber adjuster from the upper ball joint stud and axle beam. If required, use Ball Joint Removing Tool D81T-3010-B or equivalent to remove adjuster.
12. CAUTION: Do not use a pickle fork to separate the ball joint from the axle as this will damage the seal and the ball joint socket.
Strike the inside area of the axle as shown to pop lower ball joints loose from the axle beam.
13.Remove the front wheel spindle and ball joint from the axle.
Installation
1. Place the front wheel spindle and the ball joints into the axle.
2. Install lower ball joint stud nut and tighten to 113-153 N-m (83-112 lb-ft) and continue tightening the castellated nut until it lines up with the hole in the stud. Install the cotter pin.
3. NOTE: If camber adjustment is necessary, special adjusters must be installed.
Install the camber adjuster in the upper front wheel spindle over the upper ball joint stud. Align adjuster properly.
4. Install the clamp bolt and nut into the axle boss. Tighten the nut to 68-92 N-m (50-67 lb-ft).
5. Install the front disc brake rotor shield.
6. Pack the bearing cone and roller and front wheel bearing with a lithium-base grease, Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B. Use a bearing packer. If a bearing packer is unavailable, pack the bearing cone by hand working the grease through the cage behind the rollers.
7. Install the bearing cone and roller and wheel hub grease seal as described in this section.
8. Install the hub and rotor on the front wheel spindle.
9. Install the front wheel bearing, washer, and nut. Adjust bearing end play.
10. Install the nut retainer, cotter pin and dust cap.
11. Install the disc brake caliper.
12. Connect the steering linkage to the front wheel spindle. Tighten the nut to 76-104 N-m (56-76 lb-ft) and advance the nut as required for installation of the cotter pin.
13. Install the wheel and tire assembly.
14. Lower the vehicle.
15. Check, and if necessary, adjust the toe setting.
16. Check the brakes for proper operation.
Old Oct 23, 2005 | 07:38 AM
subford's Avatar
subford
Ball Joint, Upper and Lower, F-150
Removal
1. Remove the front wheel spindle (3105) and ball joint assembly from the axle.
2. NOTE: Lower ball joint must be removed first.
Install the front wheel spindle in a vise and remove the snap ring from the lower ball joint.
3. Remove the lower ball joint from the front wheel spindle. For F150 and Bronco, use U-Joint Tool T74P-4635-C and Receiver Cup D81T-3010-A5 or equivalent.
4. Turn the forcing screw clockwise until the ball joint is removed from the front wheel spindle.
5. CAUTION: Do not heat the ball joint or the front wheel spindle to aid in removal.
6. Assemble U-Joint Tool and cup on the upper ball joint, and turn forcing screw clockwise until ball joint is removed from the front wheel spindle.
Installation
1. NOTE: Upper ball joint must be installed into the front wheel spindle first.
NOTE: Individual ball joint tools are included in Ball Joint Adapter Set D81T-3010-A or equivalent.
CAUTION: Do not heat the ball joint or axle to aid in installation.
To install the upper ball joint, assemble C-Frame Assembly, Ball Joint Receiver Cup D81T-3010-A5 and Installation Cup D81T-3010-A1 and D81T-3010-A3 or equivalents inside cup D81T-3010-A4 or equivalent in position on the front wheel spindle.
2. Turn forcing screw clockwise until ball joint is seated.
3. To install the lower ball joint, assemble the C-frame in position on the front wheel spindle and repeat Step 1.
4. Install the snap ring onto the ball joint.
5. Install the spindle and ball joint assembly.
Old Oct 23, 2005 | 10:40 AM
my93's Avatar
my93
Thank you guys very much!
