I have been running the Acell plugs & wires that came with my TFI Tune-up kit. Since that time I have converted over to DSII system. I just cleaned & regapped them and they are doing great.
In my 1989 F-150 with the 300 I changed the factory Motorcraft plugs at 36,000 miles and they were still like brand new and the truck still ran great. I used Autolite Platinum's. The truck actually ran better with the Motorcraft plugs. After 30,000 miles I changed the plugs again this time using the recommended Motorcraft plugs. Interestingly enough the Autolite platinum plugs didn't wear as well as the original non platinum Motorcraft factory plugs.
Has anybody tried this with success (using plugs from fuel injected 300 engines in carbureted 300 engines)? I read somewhere that the use of deeper FI spark plugs will center the spark better in the chamber of carbureted heads (it does not hit the piston in case some may wonder about clearance issues) and allow for better combustion and therefore more power and/or fuel efficiency. I also read that one guy who tried this did actaully get a lot pinging, so he went back to carbureted-type plugs (to his carbureted 300 engine). Any input will be appreciated.
Thanks, Raul
When I bought my truck it had champions in it(which are made for lawn mowers and dodge). I knew that autolite was a Ford product, so I bought them. CRAP!!!!!!!!!!!!! That's all my truck ran like. I fiddled with everthing. After awhile I puled 'em out and put Motorcraft plugs in, it ran 10 times better.
The acceleration and idle quality was much smoother. Gas mileage improved by about 1-1.5mpg. The whole time it had autolites in it the engine felt retarded.
are those non-platinum? that sounds too cheap for a platinum plug from bosch.
Yes, Bosch Super is the base plug, non-platinum. I may have confused things by mentioning having trouble with platinum plugs in another vehicle. Supers are around $1 and Platinums 1's are around $2.
I have seen more than one Bosch Platinum 1 have the tiny platinum rod slip inside the insulator. What happens is the rod drops down and bridges the spark gap. Not good!!
I have splitfires in one of my rigs, they work fine, just not any better than a normal plug. Not really worth the extra $$.
Chumpions haven't been any good since they went to copper core, and no, I don't even use them in my Mopars.
