Edelbrock 1406 question
Old May 12, 2002 | 07:36 PM
wooddy's Avatar
wooddy
I just bought a new Edelbrock 1406 for my truck. It looks like I need to buy a universal fuel line kit for it. I have an auto transmission. Does anyone know if Im going to have to buy the Ford throttle linkage adapter too? Any other suprises? Would I be better off taking the edelbrock back and buying an oem replacement?
Thanks for any info you can provide...
1979 F-350 Custom w/460 Auto Trans
and
98 Honda Valkyrie Std.
96 Taurus GL
95 Suzuki DR125SE
88 Crown Victoria
Old May 12, 2002 | 11:32 PM
jsworkman's Avatar
jsworkman
I would take it back I like the Edelbrock & Carter seires carbs they are far easier to tune than a stock carb yes you may need the ford kit with the auto trans but I would mount it first and check use the tuners book that came with the carb it can help you dial the carb into what you want you may need different jets or metering rod or springs but when your done you will be very happy I have put this carbs on a 70 428 mach 1 and a 77 bronco with a 302 my bronco got like 14-18 in town and 20 on the highway and if I was towing my old camping trailer (1968 Ranch El Rae)I got about 10-12 and it wieghted in at about 3200 lbs I use a equalizer hitch and trailer brakes I live in Salt Lake City and to get out of town its a climb I use to tow my trailer up Parleys canyon I-80 at 50-65 and thats a 6% grade with no sputtering and use it for some ruff 4 wheeling too
John Workman
76 F250 Crew Cab
Old May 12, 2002 | 11:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
You will need the Ford kit to hook up the AT kickdown linkage properly. You can do it without it by fabricating parts but the kit is easier.
The 1406 is a very easy carb to tune. From what I have seen of the OEM rebuilds the edelbrock is much better. Have you made any other modifications to the engine or emissions? If you have, the OEM unit will not work correctly, and they are very hard to tune without some baseline data.
I have no idea what is in the fuel line kit or why you would need it. I did not need it when I hooked my 1406 up on my 78 400.
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
over!
Old May 13, 2002 | 07:45 AM
dzjammer's Avatar
dzjammer
Get the AT kickdown, its only about $10-15. The fuel line kit I believe is just the banjo swivel fitting to drop the inlet below the air filter. The Edelbrock is awesome, worked right out of the box for me, just some idle speed and choke adjustment. I bought the rod and jet tuner kit, but thats just because I wanted to experiment.
Old May 14, 2002 | 12:01 AM
wooddy's Avatar
wooddy
Thanks for the encouraging words guys.
Im going to go for it.
Ill let ya know how it turns out.
Is it safe to say that this engine is a full vacuum advance setup?
It looks like I will have to figure out what to do with extra vacuum lines that are currently plugged into the stock carb.
Ill figure it out..
and
96 Taurus GL
95 Suzuki DR125SE
88 Crown Victoria
Old May 14, 2002 | 02:53 AM
Torque1st's Avatar
Torque1st
Posting Legend
Your engine should have both vacuum and mechanical advance in the distributor for street use.
The distributor should use the venturi or ported vacuum source for the main (outermost) vacuum port. A temperature sensing switch is used also to control the vacuum source to the outer or main vacuum port. When the engine is cold full vacuum is directed to the main vacuum port. When the engine warms up the temperature vacuum switch moves and connects the venturi vacuum to the main distributor vacuum port. Some distributors have a dual vacuum port modulator, on these the inner unit is connected to full vacuum.
Hope this helps.
over!
Old May 14, 2002 | 02:54 AM
wayne_j's Avatar
wayne_j
Old Nov 18, 2005 | 06:10 PM
derherr65's Avatar
derherr65
Try this link. I just got mine done. It's got instructions and a drawing for a simple kickdown.
https://www.ford-trucks.com/forums/s...ickdown+400+c6
Old Nov 18, 2005 | 06:40 PM
User 71024's Avatar
User 71024
and
96 Taurus GL
95 Suzuki DR125SE
88 Crown Victoria
You should be able to get the 1406 with the ford kickdown linkeage. I've got one on my stang.
Old Nov 18, 2005 | 06:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
This thread was 3 years old, the project long over...
The archives are great for looking up info, but not so good for finding questions to answer. Watch the dates.
fmc400
General Automotive Discussion
Oct 31, 2011 07:57 AM
Fordman96
Sep 4, 2011 05:50 PM
Old Rust Bucket
16
Mar 2, 2007 11:27 AM
ceprice
Jan 31, 2004 08:00 PM
