Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
1/2" copper air lines
Old Oct 21, 2005 | 12:26 PM
missalot's Avatar
missalot
I have a few coils of 1/2" copper tubing I was planning on running to distribute my compressed air around my shop. With the maximum run being about 35 feet from the storage tank, what kind of CFM limitation would I be looking at with a working pressure of 90-100 psi?
Old Oct 21, 2005 | 02:38 PM
stryder's Avatar
stryder
I would NOT use flexible copper tubing for air lines. That stuff has pretty thin wall if memory serves. spend some money and buy type L tubing. It thick wall stuff that will hold its own. Also use 95/5 tin solder or copper brazing alloys. Do a topic search. This has been discussed so much there are TONS of threads.
Stryder
Old Oct 21, 2005 | 02:52 PM
91-Exploder's Avatar
91-Exploder
For air lines you need type K or L 3/4" or 1" tubing K is heavier but harder to find. You then come to the fun part of this you need to silver braze the copper tubing so the tube joints do not experience a fatigue failure under load.
Old Oct 23, 2005 | 06:14 AM
80f100302's Avatar
80f100302
I was thinking about using PVC. I have seen PVC used in a couple of shops.
OK, I will not be using PVC after reading the other threads!!!!!!
Old Oct 23, 2005 | 04:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Good choice!
Check out the FAQ thread for info.
Old Oct 24, 2005 | 01:53 AM
Crash687's Avatar
Crash687
1/2" soft copper will work just fine. just keep it protected from where something could smash it flat. it is offered and used in refrigeration systems all the time which subject it to more heat and pressure than compressed air ever will. do note that refrigeration pipe sizes use O.D. for measurement and water pipe refer to I.D. example: 5/8" refrigeration is equal to 1/2" water. 7/8" refrigeration is equal to 3/4" water.
Old Oct 24, 2005 | 10:47 AM
missalot's Avatar
missalot
Thanks for all the useful information. I am still curious if I will be limiting myself for future use by only running a 1/2" line across my shop.
Given a 35' run of 1/2", what would be the approximate limit of CFM? - I am not having much luck finding this info with the search feature.
-Missalot
Old Oct 24, 2005 | 01:16 PM
Huntsman's Avatar
Huntsman
I can't give a "CFM' answer but I can say that I also used 1/2" hard copper after removing pvc pipe and ran it across three 12' bays and down both walls (approx 45'). I painted my truck, using a Devilbiss plus HVLP paint gun on the longest leg, without any problems and I routinely use air tools on that drop without any concerns.
Old Oct 24, 2005 | 03:07 PM
imlowr2's Avatar
imlowr2
I'm running PVC in my garage (OK, stop throwing things at me). I've never had a problem with air lines. I run about 120 psi of air daily. I noticed the Goodyear tire and several repair stall near me also run the PVC pipe. Mines been in the garage for about 5 years now.
Old Oct 24, 2005 | 06:09 PM
Maxium4x4's Avatar
Maxium4x4
PVC is an explosion waiting to happen. If it kills or injures anyone, you knew it from the start.
Old Oct 24, 2005 | 07:48 PM
OSin86's Avatar
OSin86
Not a chance if you set it up right. Grouping "pvc" is the real danger here. If we're talking about that hpvc thin wall crap then yes, it's too risky. If we're talking about something like 1" SCH80, you'll never hurt it with a shop system unless you back into it with a truck. I've been using SCH80 to air blast drill holes for over a decade now with not one breakage. Common blast pressures of 250-300PSI and running pressures around 185 @ 350cfm. The stuff gets hot with that much air going threw it too.
As far as the 1/2in flex copper, sweat the joints and you'll have no problems. Even a proper brass compression fitting will work fine. 1/2in is plenty big for the cfm you need in a 35ft run.
Old Oct 24, 2005 | 11:20 PM
Howdy's Avatar
Howdy
I've done searches all over the internet and it's hard to believe people still use pvc. The thickness of the pvc isn't the problem, it's the chemical make up of the stuff. The process they use to make pvc flexable, so you can bend it around in ditches, is the reason it will come apart and blow shrapnel. It's chemistry. Check out the FAQ at the top of this forum. Lots of good info.
The chart I have lists 1/2" steel pipe good for 50' at 20 cfm. I imagine your copper will be fine at 35'. (Remember the figures on these tables don't take any bends into account.)
Old Oct 24, 2005 | 11:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
imlowr2 & OSin86- Now that you have posted here and left a "paper trail" and anyone is injured you have a real problem when the legal dogs get you... Get rid of the PVC. It is the MATERIAL that is dangerous not the thickness. Contact the PVC manufacturers.
A transmission shop near me runs PVC and had a line blow in the middle of the night when nobody was around. They repaired it with more PVC...
Old Oct 25, 2005 | 01:01 AM
fixnair's Avatar
fixnair
Unhappy
Any compressed air system will expand and contract as pressure rises and falls. This fatigues the pipe and eventually leads to failure even in an iron piped system. The life cycle of PVC under these conditions is miniscule compared to iron or copper. When it does let go it usually is catastrophic. Someone could easily get hurt!
Old Oct 25, 2005 | 04:10 AM
crewzmaster's Avatar
crewzmaster
For my 2 cents worth, use either threaded steel pipe or stainless steel tubing with compression fittings(for its strength over copper) or a combination of the both. If you put low point drains/blow downs in the line and then at the end, you can keep what moisture does get in there blown out. Should last a lifetime done this way with no safety concern.
