Full urethane bushing set????
Old Oct 20, 2005 | 01:41 PM
Jerrod's Avatar
Jerrod
I am have a clunk that feels as if it comes from under the floorboard on the driver side. I am guess it is probably a swar bar bushing problem, although I haven't had time to pull sway bar off to check. It happens in drive or reverse when you are just letting the engine idle and move you forward just crawling. There is no pattern to the clunk to speak of. It appears to go away at higher speeds, but may just be covered by road noise. Energy suspension has a full hyper flex kit for the truck that has front and rear sway bar, front and rear leaf spring, and front track rod bushings. Does anyone see the point to replacing all these parts or should I just order the front sway bar set? All of this is for a '00 f-250 7.3L crewcab with 120K on it. Any opinions??
Old Oct 20, 2005 | 02:15 PM
Jerrod's Avatar
Jerrod
Just had another thought reading through old postings......could this be the infamous driveline clunk?? If so, can it wait for another 25K to get fixed??
Old Oct 20, 2005 | 02:42 PM
AustinS's Avatar
AustinS
I've had the same issue a few times on my '01. You can replace the sway bar to axle bushings with poly ones but the end links are a Ford item. I replaced my end links 2 times in 42,000 mi. You could also have a body mount bushing, front wheel hub/bearing, ball joint, or front axle u-joint issue also. If it drives fine and is just popping once its probably the sway bar to axle bushing. If it thumps constantly on a bumpy road probably sway bar link.
Good luck,
Austin
Old Oct 20, 2005 | 02:49 PM
Jerrod's Avatar
Jerrod
Essentially it thuds a few times, maybe 3-5 times, as you crawl forward then it seems to disappear or gets buried by road noise. Energy suspension has the full set of urethane.
Old Oct 20, 2005 | 03:16 PM
AustinS's Avatar
AustinS
If they have full urethane sets, you might have to buy new sway bar end links. On my '01 I couldn't press the bushing assy out of the link without destroying it. Maybe someone will chime in and correct me on this, but the bushings on mine were a none serviceable item. I couldn't just buy the bushings. I know I've seen bushings advertised, but they didn't work on my application.
Austin
Old Oct 20, 2005 | 03:50 PM
SpringerPop's Avatar
SpringerPop
Did you try a gas torch to remove the old, non-servicable, ones?
Is that even an option?
Pop
Old Oct 20, 2005 | 04:16 PM
Jerrod's Avatar
Jerrod
If I am not mistaken, a gas torch can be used to heat the rubber, or melt actually, then they can be pushed out.
Old Oct 20, 2005 | 05:29 PM
guthrie&co's Avatar
guthrie&co
be careful on which set you order i just ordered a set frrom energy suspension and durin g the install the drop link bushings didnt fit. so as i type, i am on the phone with them trying to get the right parts. they are aware of the situation but i am on hold so i cant explain anymore. so justbe aware of this issue. i will tell you more when i know more.
Old Oct 20, 2005 | 05:30 PM
Jerrod's Avatar
Jerrod
Thats not good news! They are shipping mine today 2nd day air....hopefully it gets figured out!! Please let me know ASAP so I don't tear into anything that can't be fixed.
Old Oct 20, 2005 | 05:44 PM
guthrie&co's Avatar
guthrie&co
ok i just got off the phone and the deal is the truck they test fitted had some mods that they didnt catch. so they are sending me the rear sway bar bushing kit. it is supposed to fit the front drop links. call em on the phone and ask for the tech department and they will fix you up. i have the number and i can send it in a pm if you want it.
Old Oct 20, 2005 | 05:55 PM
Jerrod's Avatar
Jerrod
Can you send me the number please?? Do you recall what part numer you had originally ordered??
Old Oct 20, 2005 | 05:58 PM
guthrie&co's Avatar
guthrie&co
pt number 4.5186g the g stands for graphite inpregnated.
949-361-3935 energy suspension
he just called me again and they told me that he could not overnight to me on his dime. so he is going to send it ground. i will have em next week. i also told him about your situation and he is aware and is awaiting your call right now.
Old Oct 20, 2005 | 06:16 PM
Jerrod's Avatar
Jerrod
So the 4.5186g is the correct number??
Old Oct 20, 2005 | 06:22 PM
guthrie&co's Avatar
guthrie&co
yes. it is the right part number for a 99 ford f 250. what model do you have?
Old Oct 20, 2005 | 06:25 PM
Jerrod's Avatar
Jerrod
I have a '00 f-250. I just double checked and that is the part number they sent me. Good thing to since it already went out. Are you having the clunk like I described when you are in drive or reverse just kinda crawling along under idle?
