quick heater box ????
Old Oct 20, 2005 | 10:41 AM
low springs's Avatar
low springs
i just found a stock heater and installed it in my truck. i forget which one is the inlet and outlet?
also i'm running a 302 in my 58. which one is the inlet and oulet as well from the motor?
it's getting cold, i need some heat.
Thanks
Old Oct 21, 2005 | 12:00 AM
Col Flashman's Avatar
Col Flashman
Upper should be "In" & the Lower should be "Out".
Old Oct 21, 2005 | 08:58 AM
hiball3985's Avatar
hiball3985
Col is correct, on the engine the in is at the water pump,this goes to out on heater(lower connection).... out at the intake manifold, this goes to in on the heater(upper connection
Jim
Old Oct 21, 2005 | 10:41 AM
low springs
thanks guys, i'm going to do it this weekend....
Old Oct 21, 2005 | 10:42 AM
ford390gashog's Avatar
ford390gashog
it does not matter at all which one you use for in or out
Old Oct 21, 2005 | 10:50 AM
hiball3985's Avatar
hiball3985
yes it does.........lol and now that I reread what I said, I have it backwards..sorry
Old Oct 22, 2005 | 12:10 AM
ford390gashog
how so??????? it really does not matter which one gets used for a inlet and outlet. it will all flow the same.
Old Oct 22, 2005 | 12:41 AM
low springs
so it doesn't matter then? i can see how that's true.... Thanx
Old Oct 22, 2005 | 03:10 AM
Earl's Avatar
Earl
Only issue is getting all the air out of the heater core. Filling from the bottom will do that more easily, but you could probably do it filling from the top as well.
Old Oct 22, 2005 | 07:53 AM
hiball3985's Avatar
hiball3985
it will work eithier way, but according to a freind who was in the radiator bussiness for 45 years, filling from the bottom removes air pockets and allows for better heating, also was said in the instructions for a aftermarket heater/air unit I installed, and Ford shop manuels also show it connected that way
celsoglima
1983 - 2012 Ranger & B-Series
Dec 16, 2016 09:06 AM
Shadowrider123
Dec 1, 2012 05:48 PM
ttttmaxx
46
Jun 20, 2012 11:28 AM
rockyrider
20
May 19, 2005 09:52 PM
makthenif
Jun 15, 2004 08:54 PM
