Icp sensor question
Old Oct 20, 2005 | 10:07 AM
krija's Avatar
krija
Icp sensor question
1995 PSD, International model engine
1. I am changing out the icp sensor... the new one I get from the ford store
looks NOTHING like the sensor that is in there now. The one in there now
has a metal, mushroom shaped housing below the connector and above
the
bolt that screws into the engine.
2. I am presuming that the icp sensor has changed its look over the past
11 years. Is this correct???? Can you squeeze a wrench under the above
described housing to take out the sensor....or is there a more appropriate
technique????
3 Please advise... I am fairly certain I am at the right sensor based on
several diagrams i have check out
4. Thanks for alll advise to a first time PSD owner trying to make this great
machine reach its fullest potential
Old Oct 20, 2005 | 11:53 AM
Craze's Avatar
Craze
krija;
Here is all I can help you with - was it one of these part numbers?
(Ford) F4TZ-9F838-A (94/95)
(Ford) F6TZ-9F838-A (96-up; marked Julian date 6318 or higher)
Here is the Intenational part number:
(International) 1830669C92
Old Oct 20, 2005 | 08:40 PM
1997F-350's Avatar
1997F-350
i just replaced mine two weeks ago.
to remove the old one grab onto it with some channel locks and loosen it up. then put the new one in i think it requires a 1 1/16 socket.
Old Oct 20, 2005 | 10:52 PM
krija's Avatar
krija
thanks alot
Old Oct 21, 2005 | 01:56 PM
ceopi's Avatar
ceopi
I just changed mine the same way 1997-350 said...
chadjones99
Jan 31, 2015 07:31 PM
Kowdog
45
Jan 8, 2014 12:07 PM
Snuggyworm
Jan 6, 2014 09:31 AM
MONAVIERONJON
Jun 17, 2013 08:06 PM
gamaliel
Jan 7, 2013 08:33 AM
