1978 - 1996 Big Bronco
'87 4.9 w/broken timing gears
Old Oct 20, 2005 | 02:04 AM
jwandhistools's Avatar
jwandhistools
Exclamation '87 4.9 w/broken timing gears
'87 4.9 w/broken timing gears.
Is this an interference engine?
Old Oct 20, 2005 | 06:58 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 20, 2005 | 08:37 AM
Kemicalburns's Avatar
Kemicalburns
depends were you driving it when it did this? only real way to find out is pull the head off and see.
Old Oct 20, 2005 | 12:48 PM
jwandhistools
drove it home.
parked it.
would not start the next morning.
motor turns over but cam does not turn.
Old Oct 20, 2005 | 12:50 PM
Kemicalburns
then i say you got luck and are fine. this happend to me once on an fe motor.
Old Oct 20, 2005 | 12:52 PM
jwandhistools
Yeah, I just bought the truck in this condition.
Guess I'll go get greasy now.
Thanks for the advice.
Old Oct 20, 2005 | 01:06 PM
andym's Avatar
andym
It's a non-interference engine.
You'll need a puller to get the harmonic balancer off, and another puller to get the timing gears off. If you've spun the motor, you'll have to make sure you line it up so the valve timing is right. If you can still see the dots on the timing gears, you can spin one around until you get them lined up right.
Alanok
1947 and Older Ford Trucks
21
Jun 30, 2016 05:51 AM
Alanok
1966 - 1977 Early Broncos
17
Nov 24, 2012 07:40 AM
shorebird
Feb 16, 2009 09:13 AM
fordcouple99
Oct 9, 2008 09:54 PM
jh8128
Missouri Chapter
Mar 31, 2007 10:55 PM
