Ballast resistor for MSD?
Old Aug 2, 2013 | 07:21 AM
fmc400's Avatar
fmc400
MSEE
Originally Posted by LI250
If it was originally part of the dash harness why is it "required"?
Is may be required for the component to operate properly but if its built into the harness your not required to install another.
I'm not sure I understand what you mean. The ballast resistor is required. There are two ways to satisfy this requirement: (1) use the ballast resistor that is part of the original wiring harness, or (2) install a separate ballast resistor if your original wiring harness is missing. They are mutually exclusive options. I feel I made this rather clear:
Originally Posted by fmc400
The ballast resistor was originally part of the dash harness. If yours is gone, you can mount a standalone power resistor to the firewall from a Mopar application.
Old Aug 2, 2013 | 07:36 AM
LI250's Avatar
LI250
Originally Posted by PRIMERED79 SHORT BED
Surely i don't need the resister with the Dura spark II system do I?
I was thinking that was for only points.
The ballast resistor is required for Duraspark II, just as it is with points.
Perhaps a less confusing way to answer his question would have been to add "however, it is built into the factory wiring" to the end of your original reply.
Old Aug 2, 2013 | 09:02 AM
fmc400's Avatar
fmc400
MSEE
This seems to be an argument over semantics rather than technical content, but in my original post, I directly answered what was essentially a yes or no question with no assumption about existing wiring. Half the people who come to this forum with ignition questions are doing so because they're working with something that doesn't work or has been modified.
Is it required? Yes. Is it part of the original harness? Of course, but that wasn't the question. Only until asked specifically how to implement this piece did I go into further detail, which was made explicit:
It's part of the original wiring harness because it is required. You are of course not required to add one if you already have it as part of your original wiring, but I can't assume that's what this individual is working with right off the bat. Instead, I start off stating the facts, and leave it upon the individual asking the question to understand how their setup differs from what I have described (with my guidance as needed). Your style of answering the question would have been just as acceptable for me too; it's simply different than mine.
Old Aug 2, 2013 | 10:51 AM
POPAJON's Avatar
POPAJON
X2 on that fmc400. I have a 77 with the duraspark2 ignition and I bought a MSD blaster 2 coil. The speed shop said I needed a ballast resistor to go with it. I disagreed cause I already had one with the stock ignition. We agreed to disagree. In the long run I was right and NO problems. I understood what you were trying to explain and why.
Old Aug 2, 2013 | 11:02 AM
LI250's Avatar
LI250
All I am saying is if someone who is obviously not familiar with a topic asks "Do you have to have a resistor?" and you answer "yes" they will most likely install it with the MSD which leads to added expense and work because you answered the question with a black and white answer. Then again I live in the grey area so what do I know.
Old Aug 3, 2013 | 10:10 PM
PRIMERED79 SHORT BED's Avatar
So how can i find out if i have a factory resistor installed or not?
Old Aug 3, 2013 | 10:19 PM
fmc400's Avatar
fmc400
MSEE
It's bundled in the dash harness, with the words "DO NOT CUT OR SPLICE" stamped along its length. It's usually RED or PINK. In lieu of searching for it, you can check for it electrically in the case of Duraspark II. Turn the key to RUN and measure the voltage at the positive (BATT) terminal of the coil. If it's 6 to 7 volts, the resistor is there. If it's 12 volts, the resistor is not there. Measure the voltage at the same place with the coil disconnected and it should jump up to 12 volts.
Old Aug 3, 2013 | 10:45 PM
fmc400 thanks, i will test it tomorrow and check back.
Old Aug 4, 2013 | 02:21 PM
OK checked the voltage.
It was 6 volts plugged in, and 11.3 with it unhooked, so it looks like i have the ballast resistor .
How can i test the coil to see if its defective?.
Old Aug 4, 2013 | 02:26 PM
fmc400's Avatar
fmc400
MSEE
Agreed, sounds like you're powering it from the factory ballast resistor. Nice work on the measurements.
You can check for gross failure of a coil by measuring the primary and secondary winding resistances. Between the two smaller terminals you should see about 1 ohm (not counting meter lead resistance). Between either small terminal and the large center terminal, you should see between roughly 7 and 11 Kohms.
eficat
Jul 29, 2011 09:00 PM
1ford1
Sep 7, 2007 07:47 PM
FordMan2
Jul 26, 2007 08:07 PM
himmelberg
48
Sep 21, 2004 02:59 PM
ClatonK
Electrical Systems/Wiring
Jan 4, 2004 03:51 AM
