HD Block Casting #
Old Oct 19, 2005 | 05:40 PM
77300i6's Avatar
77300i6
Exclamation HD Block Casting #
Ok, I know this has probably been discussed to great length before, But I would like some info on a HD block casting #.
I did some searching on here earlier today and found a post containing
HD casting #'s . They are as follows from that thread: C5AE, C6AE, C9AE, and D5TE-AA.
The casting # on my block is D5TE-60xx (15 or 75??, couldn't make out the last two #'s very well)-AA.
Is this a HD block?
If so would it have a forged crank?
Is it possible to have a HD block w/ a cast crank?
Sorry for all of the questions, I'd just like to know what are the chances that a '77 F150 4x4 would have a HD crank? This is also a non-emission engine as per the emission decal.
I seem to recall someone mentioning that the HD duty engines had an alternator bracket that was unlike the standard engines of the day. Anyone care to elaborate on this or recall if this is a fact? If so what would that alternator bracket look like?
WHEW!!! Sorry about the long post, just would like to know the possibilities.
Here is that thread: https://www.ford-trucks.com/forums/s...ghlight=d5teaa
Old Oct 19, 2005 | 08:02 PM
oldhalftons's Avatar
oldhalftons
There is no HD block.
The forged crank #'s are:
C5TE-F
C6TE-G
forged cranks were only put in medium duty trucks.
Old Oct 20, 2005 | 08:21 AM
77300i6's Avatar
77300i6
I did some more searching on this site about the 300HD. My block sounds like it is one.
stamped steel alternator bracket, Non-emissions, carb spacer does not have egr provisions (it has a vaccum port for thr power booster). Also it appears that the HD engines came with the cam gear bolted on, instead of pressed on, and a HD cooling system. Which I thought my radiator was a V8! one.
Can ayone else eloaborate? Thanks. I'll look at my cam gear sometime.
Also my emissions sticker reads "....conforms to 1977 HD fueled engines"
Old Oct 20, 2005 | 09:30 AM
oldhalftons
the stamped steel alt bracket is used for all engines without an air pump (after the pump was introduced) or the air pump on the drivers side, like vans without PS.
"Also my emissions sticker reads "....conforms to 1977 HD fueled engines" this was used after '75 to get past having cats and is on everything but an F100, later it was only used on trucks over 8000lbs
Old Oct 20, 2005 | 09:45 AM
77300i6's Avatar
77300i6
Thanks, Oldhalf tons.
I'm not really concerned about having a forged crank, the cast is suitable enough (unless your running 6.5k rpms under 12 lbs of boost )
I would just like to really know a little more info about HD blocks. (yes, I did search)
I'm not going to bother with a forged crank unless I trip over one for a decent price
Although, it would be nice to say "Yeah, it's got a forged crank, blah, blah, blah..."
Old Oct 20, 2005 | 02:38 PM
Motorhead351's Avatar
Motorhead351
The blocks were the same as oldhalftons pointed out.
Ford produced an SVO 300 block, believe it or not. They weren't put in production vehicles though.
bigblockcapri460 has one, if you look in the turbo sticky at the top of this section, he mentions some details of the SVO vs your standard block, at least it used to be there, I think the moderator trimmed it down some, not sure if that info is still there.
Hope you find one.
Old Oct 20, 2005 | 02:43 PM
77300i6's Avatar
77300i6
I know about the SVO blocks, and yes you are correct. I would have an easier time finding a 7 litre Galaxie
If there is no such thing as a HD block, then why is there info here and on fordsix.com?
I'm not ppicking a fight, but there seem to be conflicting answers. Anyhow, I just wanted to be as educated as possible about it all. Thanks.
Old Oct 22, 2005 | 08:50 AM
Motorhead351
Its my understanding it just boils down to the crank installed, HD used a forged crank, non HD used cast, both used the same block.
No problem, I don't feel your starting a fight, its better to question than take someones word for it, IMO.
jim'shighboy
Feb 3, 2008 11:01 AM
St_alfonzospancakebreakfa
Apr 4, 2004 03:20 PM
Tenor
Mar 17, 2004 09:16 AM
DrFord
Jun 20, 2001 04:45 PM
rusty79
16
Apr 28, 2001 08:07 AM
