General Automotive Discussion
351w out of truck into PINTO
Old 10-19-2005, 04:42 PM
1984-3/4ton's Avatar
1984-3/4ton
1984-3/4ton is offline
Talking 351w out of truck into PINTO
I got myself an 84 f250, it was given to me with a blown transfer case and no drive shaft. The motor is a 351w with 150k miles on it and it runs great. But the truck is starting to rust out and i found a 73 pinto with 11k miles on it and its only gonna cost 500$ bucks. Now i never thought i'd find myself to do this but after i saw another pinto with a 5.8 in it i fell in love. Now before u guys jump to conclusions on this subject about how im doing it let me explain. The motor, trans (4 speed granny), and the 410 rear are going into the pinto in some way, i dont have a real solid plan but its gonna have to work. But what i wanna ask is if any of u people have done this kinda thing to a pinto and if you have how fast was it? I know 71-73 pinto are the lightest somewhere around 2200 lbs and i've read that a stock 351 will run the pinto into 13's. And yes i know the things tend to explode into flames when hit from behind but i dont care as long as im havin fun!
Any comments are apriciated especially if u have any experience. Thanx
Old 10-19-2005, 04:49 PM
ghunt's Avatar
ghunt
ghunt is offline
If I might ask, why the hell do you wanna put a truck transmission into a pinto? You'll probably have to hack up the trans tunnel to make it fit. And the truck rear axle will most likely be way too wide.
And...honestly, I kinda doubt a 351W with a 2-barrel and 150K on the clock is gonna get a pinto into the 13's. Thing probably has 160 hp at most by this point.
Old 10-19-2005, 05:29 PM
cjben's Avatar
cjben
cjben is offline
a friend I work with had mustang 2 with a 351w in it. that thing would haul the mail,let me tell you!! he was running an auto tranny,though. not sure what he was using for a rear end. when he did the swap,he did it the right way...it looked like it came factory that way. he had it painted nice,and the interior was in great shape. He ended up selling the car for around $6000 on ebay,and only had about half of that amount invested
Old 10-19-2005, 05:37 PM
ghunt's Avatar
ghunt
ghunt is offline
Tranny was probably an AOD from a Mustang, rearend was probably whatever the II originally had in it (I think they came with an 8" rear)
Old 10-19-2005, 05:42 PM
dorkpunch's Avatar
dorkpunch
dorkpunch is offline
last week i was at the gas station fillin up. i hear this rumble and look over, sure enough, a pinto WAGON with the engine stickin out of the hood and big old duals rumbles on by. My jaw mustve hit the ground, cause the guy in front of me said, "a PINTO?!" that was exactly what i was thinking! didnt look to bad though....
Old 10-19-2005, 05:56 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Pro-Street/StateTK is offline
I had (Two) 351w pintos c-4 they had 8in rearends and the one that I raced
the most I put a 462 chunk in the 8in and I ran a 175 hp shot of NOS on it
and it ran the best was a 7.95 in the 1/8 mile with traction problems with
small slicks!
You may want to check out my gallery there are pics in there! ( hidden gallery)!
Old 10-19-2005, 06:22 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
I have only seen them put in Pintos, I never did one. The one I saw with a big V-8 (probably 351w) that I remember the most had chains in lieu of motor mounts to locate the motor.
Old 10-19-2005, 08:26 PM
racsan's Avatar
racsan
racsan is offline
ive seen a 302 in a pinto before, no reason a 351 wouldnt work, but a creeper-1st 4 spd??? get a auto. no shift lag, just hold it to the floor and let 'er rip. dont know how you'd get the rear end to hook up, be neet to make it a.w.d. let all 4 tires be pulling for you, and make good use of that engine weight up front.
Old 10-20-2005, 08:46 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
Some of the Mustang IIs came with 302s and 8-inch rear ends. The Mustang II was built on the same chassis as the Pinto, just stretched a few inches on the wheelbase so you would do well to find an 8-inch out of one and swap that in for the rear, or you're going to have to shell out some bucks to get that truck rear end narrowed. And I agree with the others about the tranny. Putting that truck tranny in there would be a major PITA and you'd never be happy with it. Go with an auto or a World Class T5 from a late-model Mustang.
And to minimize the famous Pinto "Boom Factor" yank that stock gas tank and replace it with a fuel cell.
And don't forget to beef up the chassis a bit. The V8 Mustang IIs also had an extra front subframe assembly that bolted in to stiffen things up, should be adaptable for a Pinto. It'll probably bolt right in. Stiffer front spring required too.
Have fun, and don't plan on taking corners at speed. It's gonna be just a tad front-heavy! (Hmm, do I hear Aluminum heads and intake?)
Old 10-20-2005, 11:09 AM
Pro-Street/StateTK
A stock V-6 pinto has an 8 inch rearend from the factory!
Old 10-20-2005, 11:49 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,686 Likes on 1,379 Posts
Another case of too much time and money in the wrong hands.
V8 Pinto. It's been done already.
Old 10-20-2005, 06:01 PM
rebocardo's Avatar
rebocardo
The Mustang IIs I have worked on with the 302/C-4 had a decent amount of room to get at things except for the fuel pump. I imagine it would be about the same in a Pinto. Maybe you could paint it red with white stripes on the hood like the MII.
Old 10-20-2005, 07:21 PM
ghunt's Avatar
ghunt
ghunt is offline
That sounds...scary. I would hope they were just using the chains as limiting straps, but unfortunately they probably weren't.
Old 10-20-2005, 08:09 PM
1984-3/4ton
well thanx for the remarks fellas, ill take all into concideration. And by the way i can trade the tranny for an auto and aslo i can trade the rear for a mustang 8.8 So if theres any other things to tell me let me know.
Old 10-20-2005, 10:30 PM
ghunt's Avatar
ghunt
ghunt is offline
A Mustang 8.8 still won't do you all that much good, since it's set up for coil springs & control arms vs. the pinto's leaf springs.
Quick Reply: 351w out of truck into PINTO
