I have a early 99 psd. I scanned the codes tonight just for the hell of it and came up with code P0113. I did a forum search and came up with Air Intake Temp sensor??? The crappy old air filter has been replaced in this truck with a open air type filter. This filter is just setting in the old filter box with the box lid removed. What does this sensor do, and what if any performance am I missing with this code being on. The truck seems to run fine ( as good as any truck with 190000 miles does )
Any and all help is much appreciated......
By the way, when I try to clear the code, It does not seem to go away. I am using a tuner to read the code. It asks me if I want to clear the code, I say yes...It says it is clearing the code, but when I re-scan it it is still there. I have not started the truck again.....Am I missing something?
It's probably still in your old air box. It comes out with a quarter-turn. Plug it back in and the code can be cleared. Zip-tie it to anything so it doesn't flop around and get broken. It doesn't matter where you put it. Just secure it.
