Modular V10 (6.8l)
Fuel Guage Issue
Old Oct 17, 2005 | 12:41 PM
riverratmike's Avatar
riverratmike
Fuel Guage Issue
I have a 99 F-250 V10 with 90K. My fuel gauge just recently quit working and is reading a fuel tank constantly when my truck is running, then goes to empty when ignition is off. Every so often the gauge will move off full but not much and then goes back to showing a full tank when I'm below a half tank of gas. Anyone know what I could do to fix this problem? If I can't fix it I'll have to take my truck in. I'd appreicate any feedback thanks.
Old Oct 17, 2005 | 12:49 PM
michaelmueller's Avatar
michaelmueller
It sounds like it could be either a) a faulty ground wire or b) a faulty sending unit. I would check for a ground problem first and then go from there, if the sending unit is bad, you'll have to pull the fuel tank or the truck bed to replace it.
Old Oct 17, 2005 | 12:51 PM
riverratmike
ok where is the ground wire located at? you know?
Old Oct 17, 2005 | 01:10 PM
michaelmueller
there should be a ground wire coming from the sending unit on top of the fuel tank, probably in a wire harness, follow it to the location that it grounds to on the chassis, check for bare wires, rusted wires, crappy connection at the sending unit itself or at the ground at the chassis. Is this an intermitting problem, or does it happen all the time?
Old Oct 17, 2005 | 01:16 PM
riverratmike
99% of the time the gauge doesn't work and is reading a full tank when the ignition is on or the truck is running. Every so often the needle will move off of full ever so little but then just returns to full in a matter of minutes.
Old Oct 17, 2005 | 01:43 PM
michaelmueller
There are definetly more knowledgeable people on this site than me, but i'm sticking with my original diagnosis. Bring her up to Michigan and I'll fix her for ya, we'll even have a couple a beers.
Old Oct 25, 2005 | 04:25 AM
riverratmike
well disconnecting the battery didn't fix it. I took it to my dealer today and they told me it needs a new fuel sending/fuel pump unit and they will have to drop the tank. Should have it all fixed in a few days. We'll see what happens.
Old Oct 26, 2005 | 02:40 AM
riverratmike
well they quoted me $350.00 for the fuel pump/sending unit. My warrenty doesn't cover the sending unit but it the fuel pump was bad it would. I'm very upset about this whole thing.
Old Oct 26, 2005 | 11:01 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I feel for ya...
Check the wiring and connections first...
However, $350 is a decent price for a fuel-pump replacement...
Old Oct 26, 2005 | 10:10 PM
Fredvon4's Avatar
Fredvon4
You can do the removal and replacment in less the 1.5 hours if you want to just buy the new pump and sender... not hard at all on these trucks if you be sure to have very little fuel in it.
Old Oct 26, 2005 | 11:17 PM
88svt's Avatar
88svt
Like Fred said, this isn't a hard job. I have to do it every two years or so on my 88 f150, either one tank or the other goes bad. Ford had a problem with these units back then. Although it sounds like the dealer has it now so I guess I'm a bit late.
Good Luck!
Old Oct 27, 2005 | 07:52 PM
Tony G's Avatar
Tony G
My '99 was stuck on full also. It turns out that the float design allowed the diamond shaped float to rotate as it moved up. When completely full, the float was up against the twist off cap and stuck on top of the inner lip. Turns out that Ford found out this problem and redesigned their float to not rotate. You CAN buy just a sending unit from aftermarket. My fuel pump went out just after my local garage replaced the sending unit (when we had the bed off) and then ford replaced it with the $200 sending unit/fuel pump. I'd say that if you have over 100,000 miles on the truck let them replace the fuel pump along with the sending unit. If under 100,000, then maybe get an aftermarket unit and takle it yourself.
Tony
Old Oct 28, 2005 | 02:30 AM
riverratmike
Tony
that's what happened I ended up filling up the tank completely even when the truck was at a slant and it let more fuel go in the tank than on level ground, that's when this whole thing started. After that fill up. My super duty has 90,000 miles.
Michael Paul
Aerostar
17
Jul 23, 2007 09:56 PM
Alta
Feb 28, 2006 03:53 PM
LWJ96F350
Feb 18, 2006 03:52 PM
backhoeken
Electrical Systems/Wiring
Jan 10, 2006 06:37 PM
JDemo-in-NC
Dec 30, 2005 05:06 PM
