What is the problem? Can't start...
Old Oct 17, 2005 | 09:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Flathead starters were known for dragging their armatures on the field coils. When you hit it with 12v, it may have put enough of a bow in the shaft to allow the armature to drag badly. It was a common trick to turn the armature down .050" to increase clearance, makes them spin faster. I would take the starter back out and try it connected to a battery on the ground (hold onto it tightly!) It should spin freely and with no noise.
If there is rust or something built up on the cylinders, I would soak the cylinders with oil before trying anything, or you'll make things worse.
Old Oct 17, 2005 | 11:29 PM
mtflat's Avatar
mtflat
I should save this info, I've typed it so often. It's very doubtful you broke the bendix spring because you jumped it with 12V. I have run a 6 volt starter on 12V daily for the past 4 years, starting it several times in the course of a day. I've only broken one bendix spring in all those starts.
Flat springs have a tendency to break anyplace there is an imperfection, irregularity or even a scratch on the surface when placed under strong load. The 12V jump only hurried up a condition that was bound to happen. Next spring you get, go over it with a piece of emery paper wrapped around various files of appropriate shapes and smooth out the sharp corners, remove edges, polish out scratches, etc. (learned this trick from shooting flintlock muzzleloading rifles for years)
I'd also agree you have ground troubles - like so many others have said.
ps. you can buy the bendix springs from Snyder's Antique Auto in New Springfield, OH. Ford used the same spring on the model A's as well as the flathead V8's.
pps. son of a gun - this is post 2500
Old Oct 18, 2005 | 09:14 AM
Scott123's Avatar
Scott123
What gauge are your battery cables? That six volt really needs a good heavy set of battery cables, like 0 or 1 aught (sp?). The cables like wal mart sells are not nearly big enough for the 6 volt amps and will get hot and melt in a hurry, and the engine won't crank very fast either.
Scott
Old Oct 18, 2005 | 11:01 AM
AXracer's Avatar
AXracer
Scott
This is very true! 6V needs twice the wire conductors as 12V to carry the same amount of current. You can get high quality larger diameter cable by the foot (you'll need to attach your own ends or they may be able to put loop ends on it for you) at welding supply houses where they sell it as arc welding cable. That's what we use for battery cables when we put the battery in the trunk on a dragracing car.
Old Oct 19, 2005 | 10:21 AM
51PanelMan's Avatar
51PanelMan
I replaced the starter solenoid and cleaned the connections a bit. The engine does turn over faster. However, now I've found that the fuel isn't traveling up to the carb. The engine starts when I use starting fluid, but then quickly dies due to no gas in the system.
Time for a fuel system overhaul. I'm starting with the tank and working my way out to the carb. Will get the tank cleaned and coated, run new fuel lines and filter, replace the fuel pump and maybe rebuild the carburater. I don't want to spend a lot of money on this overhaul because when I switch over to the SBC 350, I'm only going to use the tank and the fuel lines.
Oh, I'm also going to replace all of the cables with some welding cables and ground everything properly.
Wish me luck.
Ilya
Old Oct 19, 2005 | 11:22 AM
bobj49f2's Avatar
bobj49f2
Ilya,
I see a HUGE problem looming, worse than the starting problem, what is the SBC junk? I never took you for a "Darksider". Egads!! I think you might have opened a whole new can of worms.
BTW, now it sounds like you have a bad fuel pump. I got one from NAPA for $36.
Old Oct 19, 2005 | 11:26 AM
AXracer's Avatar
AXracer
Pull off the fuel line at the carb and stick the end in a bottle while someone cranks it over to see if gas is getting to the carb (remove the coil wire for safety). Varnish may have stuck the needle and seat in the carb. Working backwards from the carb is the better way to diagnose fuel problems. A lot of later model carbs have a filter at the fuel inlet, if the fuel line screws into a large "nut" at the carb, after removing the fuel line, unscrew that nut and there is likely to be a sintered metal filter behind it. Replace it and see if you get fuel. If you look into the throat of the carb and work the linkage to full throttle you should see a squirt of gas shoot in. (DON'T look into the carb while cranking the engine over if you like any of the hair on your head and face!)
Old Oct 19, 2005 | 12:22 PM
51PanelMan's Avatar
51PanelMan
Originally Posted by bobj49f2
Ilya,
SBC is the cheapest engine to operate and service. I'd like to get a 289 or a 351, but they are harder to come by and more expensive. I can get a part for a 350 almost anywhere (even a 7-11 store ). I'd love to keep the flathead, but I need something more reliable and worry free as this truck will be a daily and long distance driver. Don't worry, my '52 will stay original.
Ilya
Old Oct 19, 2005 | 12:42 PM
WillyB's Avatar
WillyB
Ilya
Not true - 302s are everywhere, and parts are available anywhere. They also run cheaper, break down less, and last longer. Why degrade your truck with junk?
Old Oct 19, 2005 | 01:01 PM
bobj49f2's Avatar
bobj49f2
Please , Please Panelman, don't go to the Darkside.
I just like to stoke the fires of controversy
Old Oct 19, 2005 | 01:17 PM
WillyB's Avatar
WillyB
On the practical side, ford in a ford is fine with most of us, but you lose 2/3 of your buyers when you go with something eles. Even if you are not considering selling it, that same opinion holds true when you show your truck to strangers. Most will be turned off by your engine choice even if they do not tell you.
Old Oct 19, 2005 | 01:53 PM
AXracer's Avatar
AXracer
Wow! Now there are some supportable statistics...
Old Oct 19, 2005 | 05:45 PM
  #28
ALBUQ F-1's Avatar
ALBUQ F-1
If the flattie is in decent shape I know someone who would probably be interested in it, and could probably even pick it up.
Old Oct 20, 2005 | 12:27 PM
  #29
51PanelMan's Avatar
51PanelMan
The flattie is in good condition. Ran fine before this fuel/starting issue.
It's for sale as well as my '53 Mercury flattie.
Ilya
Old Oct 20, 2005 | 09:42 PM
  #30
51frrdtrk's Avatar
51frrdtrk
SBC, isn't that the name of a telephone service supplier.
dbail3
Electrical Systems/Wiring
Sep 18, 2014 07:07 PM
nothercrash
Mar 10, 2014 08:57 PM
Wooticus
Jun 16, 2013 11:57 PM
gwcrutch
Feb 26, 2005 07:21 PM
PCS
1997 - 2003 F150
Jul 11, 2003 07:31 AM
