codes
Old Oct 17, 2005 | 09:11 AM
blue ranger's Avatar
blue ranger
Question codes
My cel is on and I Need some advice on the possible cause. I have a 90 ranger 2.3 5spd ,I have changed all sensors due to the age of the truck. I Pulled the codes which were 34,88 . Does this sound like a simple fix.
Old Oct 17, 2005 | 11:42 AM
AlfredB1979's Avatar
AlfredB1979
Did you buy the Haynes manual and check what those codes mean?
I would recommend that and get any help from the manual for those fixes.
If I wasn't 40 miles from home and away from my resources, I'd suggest further help for you....
Old Oct 17, 2005 | 07:42 PM
Ken00's Avatar
Ken00
The 34 is an EGR code, I'm thinking EVP sensor or EGR valve but you should run the pinpoint tests to determine the exact cause. Drop me an email if you need a copy.
The 88 is not in my book but it could be a tranny, AC or ignition problem.
A\Is the truck running OK? If it is I would suspect the 34 as the reason for the CEL.
Old Oct 17, 2005 | 07:58 PM
handyman43358's Avatar
handyman43358
Go to www.fordfuelinjection.com and you can learn how to read all the codes and all that. I think code 33 is no egr valve opening not detected, while 34 is PFE or EVP circuit above the closed limit of 0.67 volts, or PFE or EVP circuit has intermittently failed above the closed limit of 0.67 volts. What that means I couldnt tell ya. Code 88 is Electro-drive fan circuit failure and or Loss of dual plug input control. I had the same code until I changed my DIS computer and everything is well. It could be a fan related problem. That could be my problem to be honest. My fan kicks on when the gauge gets up above N on normal...
vaporhp
Apr 5, 2025 11:45 AM
REPORANGER
Sep 19, 2019 08:28 AM
bit422
Jul 16, 2009 09:22 AM
97 ranger 1
Jun 26, 2005 07:04 PM
