100K Question
Old Oct 22, 2005 | 02:34 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Just plain old high temp bearng grease. I use a needle tip on the grease gun and just keep going until it's full.
Old Oct 22, 2005 | 02:35 AM
WA.Ranger's Avatar
WA.Ranger
Thanks Scott, will do today.
Old Oct 22, 2005 | 07:30 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by cookie88
From what I can tell the inside races are open to each other. Every time I have the wheels off I pull the ABS sensor and pack the middle cavity full of grease.
Dunno if it helps or not but it keeps them quiet.
I keep intending to pull my old bad one apart and see just how nonservicable they really are, but I snapped the jaw off my vise a while back and haven't got around to replacing it yet.
Good idea!!! I didn't know that they were accessable. This is my next project.
BTW how do you break a vise jaw??? Kind of like breaking an anvil in half if you ask me. LOL.
Old Oct 22, 2005 | 11:47 AM
cookie88's Avatar
cookie88
FTE Emeritus
Normally I would agree. Unfortunately this little 4" job was a gift a few years back, and evidently was not of the highest quality. Snapped the sliding jaw off right above the worm screw.
Old Oct 22, 2005 | 01:32 PM
SpringerPop's Avatar
SpringerPop
Cookie,
1. Would you be VERY specific about the bearing grease you're using? If you've been doing this for some time, and haven't had a failure, you've very likely used one that IS compatable with the OEM stuff. That was my biggest concern about not doing this myself, as mixing thickener types will reduce the lubricity severely, and cause premature failure.
2. What is the indicator that you've "pumped enough"?
3. Does the hub assembly subsequently "throw" any, and if so, is it a braking concern or just a nuisance?
Pop
Old Oct 22, 2005 | 05:14 PM
cookie88's Avatar
cookie88
FTE Emeritus
Coastal uniplex high temp grease. Part #52113. It's the elcheapo stuff at Autozone in the black and gold tube, lithium complex grease. Never thought about any compatibility issues, nor have I had any. I just figured grease is grease. I haven't been doing it all that long. 50K miles or so. Started doing it after I had a bearing failure. The new one looked kinda dry, so I filled it up.
I pump it full, i.e., when the grease comes out the ABS sensor hole in the top of the hub housing where I'm putting it in.
It hasn't "thrown" any that I can discern, but it does "ooze" past the inner bearing seal a tiny bit and cake up a around the spindle. No issues at all with the brakes. That is actually the only indication I have that the grease is actualy making it into the bearings. Still can't say conclusively that it is.
Dave K
Jul 27, 2011 04:34 PM
pelletman
17
Jan 27, 2009 08:08 PM
DAVE67FD
Apr 3, 2008 04:52 PM
D&D Race
Dec 7, 2003 08:33 AM
dcarhart
4 Cylinder Engines
Oct 18, 2003 09:22 AM
