90 ford overdrive problems
Old Oct 16, 2005 | 11:46 PM
luckyf150's Avatar
luckyf150
Question 90 ford overdrive problems
Hey guys new to the board but seems very well put together. Anywyas to get to the point I have a 90 ford f150 With a four speed auto. The problem is that around 60k miles the truck decided o not shift ion to overdirve anymore and has been this way all the way to 120,000 miles. (i know i should a fixed it a while ago but ive been lazy.) And with todays gas prices i have to fix his problem. So does anyone know of any known probnlems that cause this or do the trannys just have a tendency to go bad. Any help would really be appreciated. thanks
Old Oct 17, 2005 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 17, 2005 | 07:00 PM
quaddriver's Avatar
quaddriver
AOD or E4OD?
Old Oct 17, 2005 | 08:07 PM
jlarr's Avatar
jlarr
I had the same thing happen to my '93 with the E4OD. All posts indicated toasted trans, or at the very least, torque converter. I did pull a code for excess torque converter clutch slippage. Being cheap, I changed the fluid in the trans & TC, as well as replacing the filter. OD slowly came back & has been back for many months now. Good as new for about $50 in parts.
blake 7.3L
Aug 11, 2009 05:00 PM
Togaduke
1997 - 2003 F150
Jul 26, 2004 08:54 PM
ringking
2004 - 2008 F150
35
Jul 3, 2004 08:22 PM
topdeadcenter
1997 - 2003 F150
Mar 8, 2004 03:40 PM
mini farm
Jan 28, 2004 11:28 AM
