tail lights
Old May 19, 2002 | 09:07 PM
ford429cu's Avatar
ford429cu
tail lights
I am having a problem with my tail lights not working on my truck. the truck is a 79 F250 4x4 with a flat bed and the lights and wiring from the bed are from a 76 F350 2wd. the lights are ford factory lights. My head lights work, blinkers front and rear work and when i step on the brakes my tail lights work, but when i turn the head lights on the tail lights don't light up like they should. I have tried to see what is causing thing but with no luck. If anyone can tell me what wires do what or what the problem my be it would be a huge help.
Thanks, Jeff
Old May 19, 2002 | 11:18 PM
Franklin2's Avatar
Franklin2
tail lights
I don't have a wiring diagram for a 79, but the 1980 taillight wire is brown. Whatever it is, get a meter and see if you have 12 volts back there with the lights on. We can assume you do not have a ground problem since the brake/turn lamps work OK. This wire should also go to your license plate light.
Old May 19, 2002 | 11:28 PM
Vampiro's Avatar
Vampiro
tail lights
check the wire it's self and the connection(s) on it
Old May 26, 2002 | 10:54 AM
Mil1ion's Avatar
Mil1ion
tail lights
Old May 27, 2002 | 12:08 PM
BuckyC's Avatar
BuckyC
tail lights
There is a really good article in tech section for tail lights and what the wires do. I used it on my 1975 F-250 Crewcab 4x4 and it worked great!!!!!!!!!!!!
BuckyC
Old May 27, 2002 | 04:04 PM
TheWiz427's Avatar
TheWiz427
tail lights
Check your taillight sockets and your bulbs the brake light bulbs are double filament it's possible the light side of the bulbs are blown. just a thought seen stranger things happen
Wiz
Old May 28, 2002 | 09:36 PM
7220driver's Avatar
7220driver
tail lights
Had the same problem on the right side. Fixed it by cleaning up a bad ground wire, this included a new ground terminal.
Old May 29, 2002 | 11:36 AM
russellkr's Avatar
russellkr
tail lights
[updated:LAST EDITED ON 29-May-02 AT 12:38 PM (EST)]my lights were all screwy, so I cleaned all of the sockets and any connectors I could find and then replaced most of the bulbs, now all of the lights work even when the lights are on and I am stepping on the brakes.
So first thing is to clean and replace bulbs.:7
also, there is a connector under the tailgate for the rear wiring harness, this gets pretty dirty being so close to the road, so it might be worth it to clean the connections on that as well.
