Distributor & Cam
Old Oct 15, 2005 | 01:07 AM
fordflaresides's Avatar
fordflaresides
Distributor & Cam
I am putting a fresh 1982-3 300 six in my 1973 in place of my 240. The 240/300 in the '73-'79 has 6 degree btdc timing, the 1982 has 10 degree btdc timing(stock). Does the 1982 have a different cam or is timing increased simply because it comes stock with electronic ignition? The reason why I'm asking is the distributor in my 1973 is still in good shape and if possible I would like to re-use it in the 1982 as I have become an expert at changing the points so that ain't a big deal.
Old Oct 15, 2005 | 08:03 AM
Motorhead351's Avatar
Motorhead351
I think the best way to answer that is, if you wanna run the points distributor, do so, play around with the timing until you find a happy medium. Increasing the timing over stock recommended settings, is one of the first modifications many do, put a little extra pep in your step, so to speak.
IMO, keep the electronic distributor, more spark output and you'll never change or set the points again.
Old Oct 17, 2005 | 01:54 AM
fordflaresides
that's the thing I don't have the module to the distributor, that's why I was going to use the points dist. instead of buying a module.
Old Oct 17, 2005 | 07:28 AM
Motorhead351
modules for the duraspark II are very cheap, last time I purchased one new, it was $25-30 from one of the more popular autoparts stores.
Old Oct 19, 2005 | 01:39 AM
fordflaresides
Are the duraspark II dist. the blue and grey ones.
Old Oct 19, 2005 | 07:55 AM
Motorhead351
Mine had a gray cap?
Old Oct 19, 2005 | 01:22 PM
fordflaresides
yeah, gray cap, blue distributor base.
Old Oct 19, 2005 | 02:48 PM
Motorhead351
mine had a gray distributor base?
Should you go purchase a duraspark II module, you want one with a blue tab.
Death_Eagle_571
Apr 20, 2015 09:21 PM
Junkman of Delaware
Oct 20, 2012 11:12 PM
Pop's76
Feb 18, 2011 05:27 PM
1982fordf100
Nov 15, 2005 07:17 AM
cdd5599
Oct 4, 2002 07:13 PM
