code p0460
Old Oct 14, 2005 | 09:31 PM
haroldservice's Avatar
haroldservice
code p0460
van has thrown this code twice now, no driveability issue that i can determine. it is a fuel sensor issue, any on have a clue or experience with it? thanks, harold.
Old Oct 15, 2005 | 03:39 AM
Crash687's Avatar
Crash687
P0460 Fuel Level Sensor A Circuit: Fuel Level Indicator (FLI) Circuit Check - Instrument cluster driver checks for open circuit, or short circuit.
I wonder if your sender wiring harness loose, I start inspecting it from the tank back.
Old Oct 15, 2005 | 11:15 AM
haroldservice
thanks, i will start checking that out, have to wait for service at dealer, might as well do and learn.
Old Oct 16, 2005 | 12:10 AM
PSDPlayer's Avatar
PSDPlayer
Did you fill the truck up with fuel with the engine running? The trucks get confused and think its making its own fuel.
Old Oct 17, 2005 | 01:59 AM
haroldservice
no, but the light has gone out since i did fuel up. the first time the van coded this, i had shudder in reverse, thought it was tranny, now i think the engine is cause. did have shudder again , but not at the start-up i first noticed light.
Old Oct 17, 2005 | 09:42 AM
1ReDNeCK's Avatar
1ReDNeCK
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top align=left width="100%" colSpan=2>P0460 - FUEL LEVEL SENSOR CIRCUIT MALFUNCTION</TD></TR><TR><TR><TD><TABLE cellPadding=2 width="95%" border=0><TBODY><TR><TD vAlign=top width="100%" bgColor=#c0c0c0 colSpan=2>SPECIAL SERVICE MESSAGES </TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="99%">18465 1997-2005 MULTIPLE VEHICLES - INTERMITTENT MIL ON WITH DTC P0460 - SERVICE TIP
SOME 1997-2005 VEHICLES MAY EXHIBIT AN INTERMITTENT MALFUNCTION INDICATOR LAMP (MIL) ON WITH DTC P0460 (FUEL LEVEL SENSOR CIRCUIT MALFUNCTION). THIS CONDITION MAY BE CAUSED BY AN IMPROPERLY INSTALLED REMOTE START SYSTEM, AFFECTING THE FLUID LEVEL INPUT (FLI) INFORMATION TO THE PCM. THE CONDITION MAY BE DIFFICULT TO DUPLICATE. TO SERVICE, CHECK FOR AN IMPROPERLY INSTALLED FORD OR AFTERMARKET REMOTE STARTER SYSTEM. THE INSTRUMENT CLUSTER OR HEC MUST HAVE POWER TO ALL 'HOT IN RUN' CIRCUITS FOR THE FUEL GAUGE CIRCUIT TO PROPERLY RELAY FLI INFORMATION TO THE PCM (EITHER BY NETWORK COMMUNICATION OR A DIRECT HARDWIRE CIRCUIT).
EFFECTIVE DATE: 03/11/2005
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Old Oct 17, 2005 | 11:54 AM
haroldservice
no remote start here, ford or otherwise.
Old Oct 17, 2005 | 09:00 PM
xtrm1stang's Avatar
xtrm1stang
possible overfill
Old Oct 17, 2005 | 09:42 PM
haroldservice
overfill as in spillage? the tank was at 1/4 when cel came on, ford dealer did not mention today(getting brakes worked for pulling, new pads/turn rotors, checked oil leak, could not verify). i am going to try and make it happen by sloshing the tank when 1/4 or less.
Old Oct 18, 2005 | 08:23 PM
xtrm1stang's Avatar
xtrm1stang
a p0460 code can be set if you overfill your tank, the computer will see full after filling, and as you drive it will calculate fuel use, but if it still sees full after driving a certain distance, then it will think there is a circuit problem because the gage never moved and set the light.
Old Oct 19, 2005 | 02:25 PM
haroldservice
new brake pads(with rotors turned at 15k miles, takes some off the life)seem to brake straight, harder pedal, no mention at all on the code, apparently if it clears they don't look at it.
jcmagone
Jan 3, 2024 08:16 AM
meetre
Feb 23, 2015 10:29 PM
brandon.edwards
Mar 30, 2014 05:28 PM
jonrjen
6.7L Power Stroke Diesel
Nov 7, 2013 08:03 PM
grldben
Aug 4, 2013 08:45 PM
