Turn signal question.
Old Oct 14, 2005 | 12:11 PM
trvaughn's Avatar
trvaughn
I was wondering if the turn signal is supposed to cancel after turning in my 66 f-250. Right now I have to manually move it back to the neutral position after turning. Is that how it was designed to be or is something broke.
Thanks,
Old Oct 14, 2005 | 12:33 PM
re54drider's Avatar
re54drider
Yes it is supposed to return. There is a plastic piece in with the switch that is supposed to turn it off, but apparently yours is broken. I think it will require the replacement of the switch to get that function back. I got tired of buying switches and wired in two toggle switches(but you have to really know your wiring to get that to work with the turn signal and brake lights sharing a filamint). I feel sure somebody offers a replacement.
Old Oct 14, 2005 | 12:49 PM
trvaughn's Avatar
trvaughn
Thanks, found the canceling cam in my Macs catalog and also found it at autozone.
Old Oct 14, 2005 | 07:11 PM
barry's Avatar
barry
You can still get the signal switch from Ford. I got one for one of the members 2 weeks ago.
Barry
Old Oct 15, 2005 | 04:20 AM
jowilker's Avatar
jowilker
trvaughn, The canceling cam, should get you back into bidness. The little ends are broken off the old one.
John
Old Oct 15, 2005 | 08:59 PM
jd_sylvia's Avatar
jd_sylvia
I bought a new came from Vintage and it fixed my problems. They have two styles one with wires one without. The cam with wires is for the trucks with Emergency flashers.
jd
dmarsh2400
Aug 19, 2019 03:23 PM
hertz1438
Oct 16, 2009 06:42 PM
John Morton
13
Feb 14, 2009 02:14 PM
turkyhntr
Mar 7, 2007 08:34 AM
