Dash Lights are not working.
Old May 30, 2002 | 07:13 PM
FiveO12's Avatar
FiveO12
I have changed bulbs and checked wires and nothing is working. I have turn signal lights and the right turns signal indicator is on steady burn when headlights are on.
Old May 30, 2002 | 09:13 PM
TheWiz427's Avatar
TheWiz427
Have you checked for a good ground and the fuses?
Wiz
Old May 31, 2002 | 12:51 AM
karljay's Avatar
karljay
>on.
The inst lights are seperate and should run off the small fuse. Mine uses the #3 wire, white/blue. You should be able to test it with a test light or volt meter. I think it gets it's power from the light switch to the fuse then to the back of the guage cluster.
Mine is a 73, but I don't know for sure that the wires wern't changed with the cab (previous owner swap).
I'd check for the 12volts at the light switch, then check at the fuse when the parking lights are on.
Right turn on mine has two wires both black in the #7 spot at the rear of the guage cluster.
Could be a faulty light switch, if you apply 12volts to the #3 wire (white/blue) then the lights should come on.
Hope this helps.
Old May 31, 2002 | 02:22 AM
sparky's Avatar
sparky
>on.
Check the grounds at the right turn signal/headlight ground bolt. It should be located on top right side of the rad support, two black wires. This problem is common in these old trucks. Also check the trun signal socket for corrosion.
Sparky
Old May 31, 2002 | 09:08 AM
SloWave's Avatar
SloWave
