Vaccuum Lines ?
Old Oct 13, 2005 | 09:53 PM
James W. Hitch's Avatar
James W. Hitch
Vaccuum Lines ?
Im new so dont yell if this is a stupid or reoccurring problematic question.I did search first.
I have a 1982 F-150 4X4 inline 6 cylinder.I have bought a hayes manual but its a piece of *****.What I would like to find is a diagram showing and explaining all the vaccuum lines that are there in the engine compartment.If anyone knows what lines can be removed and still function correctly or better would be helpful.I am not concerned with removing smog control stuff of that nature because it is mainly a off road vehical.If possible I would like to simplfy the vaccuum lines any info would be helpful.
I also would like to relay my headlights is there a how to guide using wire color codeing.
Thanks for the help
Old Oct 13, 2005 | 11:07 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
Please view the main forum page to find the best forum to ask any Technical questions.
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
Old Oct 14, 2005 | 12:16 AM
Franklin2's Avatar
Franklin2
You can't really remove any of the lines, without causing problems somewhere else. You could possibly remove the smog pump stuff, but I would leave the rest on there, unless you are going to go with an aftermarket carb or something like that.
If the tune of the engine is completely stock, It will not help taking anything off, and may make it run worse and cause detonation(ping).
Old Oct 14, 2005 | 12:48 AM
Bdox's Avatar
Bdox
There is usually a sticker under the hood that shows the vacuum line hookups.
But unless you are really going all high performance, aftermarket ignition and carb, don't bother. You will not gain anything and you will make your truck harder to sell.
Old Oct 14, 2005 | 08:05 PM
bluesuedetruck's Avatar
bluesuedetruck
James,
As far as the Haynes repair manual goes...keep in mind it is for repairs to a stock vehicle only. It will not tell you how to "trick out" any part of the vehicle. For the type of modifications you want to make you'll have to go to some of the many "Hi Performance" mags/sites. IMHO
Good Luck,
Ken
Old Oct 14, 2005 | 09:57 PM
James W. Hitch
OK does anybody know where I can find a wire and vaccuum diagram
Old Oct 14, 2005 | 11:49 PM
Franklin2's Avatar
Franklin2
Try this for the vacuum line schematics.
http://www.autozone.com/servlet/UiBr...3d800ce605.jsp
Old Nov 2, 2005 | 11:14 PM
CrewChief521's Avatar
CrewChief521
how come there are no diagrams for 1982 trucks on that website?
Old Nov 2, 2005 | 11:36 PM
fordborn's Avatar
fordborn
Thats strange cause my Chiltons manual doesn't show any 82 either.
Old Nov 3, 2005 | 06:12 AM
srercrcr's Avatar
srercrcr
I have an 83 300 vacuum line chart I developed myself, so I could redo all the lines.
I suspect the 82 is the same. I'd like $4 including shipping for a copy.
Old Nov 3, 2005 | 07:29 PM
Piffery1's Avatar
Piffery1
At least for wiring diagrams, Haynes manual says '80 & '81 are same and '82 & '83 are same. Probably true for vacuum diagrams, too but I don't know for sure.
