radio speaker help
Old Oct 13, 2005 | 03:28 PM
propane32's Avatar
propane32
Question radio speaker help
Every where I read says my 52 F1 uses a 6x9 speaker, but I cannot mount it where i think it would go. It seems to be to big to fit above radio. Please where does it go, and how? Thanks in advance.
Last edited by Earl; Oct 13, 2005 at 05:54 PM. Reason: A little punctuation for readability
Old Oct 13, 2005 | 06:22 PM
barry's Avatar
barry
There's a grill above the radio that's just below the stainless trim on the dash. If you remove it, there's an opening for the speaker. I believe you might be able to mount it from the back side of the dash. The shop manual has several pics in the back half of the dash and the radio setup.
Barry
50 F-1
Old Oct 14, 2005 | 01:33 PM
propane32's Avatar
propane32
barry thats where i have been trying to mount it but theres noy enough room nor are there bolt or bolr holes to mt. i will check shop manual i must have missed that section thanks clyde
Old Oct 14, 2005 | 04:53 PM
Calvin349's Avatar
Calvin349
A newer aftermarket speaker may have a bigger magnet. Not sure if that is what you have. As a test fit item try a stock one of some kind out of a junkyard car. It will have a smaller maget and housing maybe.
Calvin
Old Oct 14, 2005 | 05:03 PM
AXracer's Avatar
AXracer
The OEM would have had a very small magnet and a shallow frame/cone as well.
Old Oct 14, 2005 | 05:23 PM
propane32's Avatar
propane32
its not the depth thats the problem its the height i wonder if i need maybe a 4x10 instead of 6x9 thanks clyde
Old Oct 14, 2005 | 08:14 PM
martydread's Avatar
martydread
Not familiar with the F1 speaker, but many later model fords use a 5x7, which is sometimes harder to come by as many installers will replace the speaker with a 5.25" speaker and a mounting plate. Most larger audio retailers would stock a limited selection (brand-names) of 5x7's. You can also find them for shallow-depth applications (but you said that wasn't an issue).
Maybe they used them back then—I had a 64 mercury with 5x7 factory locations under the rear deck.
Martydread
Old Oct 15, 2005 | 01:06 PM
propane32's Avatar
propane32
thanks martydread i think you hit the nail on the head looks like a 5x7 would fit perfect
My1964ford
Nov 22, 2014 11:18 AM
4x4lugnut
Sep 17, 2013 04:47 PM
2kflhr
21
Aug 22, 2009 12:21 PM
SPINPOSI
Nov 21, 2008 12:16 AM
va98expd
Jul 25, 2004 09:07 AM
