Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Truck topper storage
Old Oct 12, 2005 | 09:00 PM
whitetailhunter's Avatar
whitetailhunter
I recently removed the topper from my truck. I was wondering if anyone had any ideas of how I could store it outside, with some easy way to take it off and put it on by myself.(or a little help from somebody else)
Thanks!
-Ben
Old Oct 12, 2005 | 09:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
Many people make a hoist with some pulleys in the garage. If you have the headroom it could be stored there.
Old Oct 12, 2005 | 10:16 PM
MisterCMK's Avatar
MisterCMK
We used to use pulleys in the garage to get the topper off with an old 1973 F-250. However, some of the newer toppers are so light that 2 people can lift it off themselves.
Old Oct 12, 2005 | 10:21 PM
whitetailhunter
yeah, I can get it off with two people, but I kinda wanted to be able to get it on and off by myself. Also, I wanted to store it outside.
Old Oct 12, 2005 | 10:22 PM
SmokyOlFord's Avatar
SmokyOlFord
Extended outdoor storage never seems to agree well with a topper. Might depend on the weather, how much long term moisture, tree sap, yard debris, critters...
-Smoky
Old Oct 12, 2005 | 10:34 PM
whitetailhunter
I plan to cover it and regulary maintain it to provent theese things to the best of my ability. I know what you are saying though, i've seen a few raccons make home under a topper
Old Oct 12, 2005 | 10:43 PM
whitetailhunter
Indoor and Outdoor storage options appriciated
I just did a little measuring, and I have the option of putting the topper in the garage, so indoor and outdoor storage options are greatly appriciated.
Thanks!
-Ben
Old Oct 12, 2005 | 11:16 PM
460f250's Avatar
460f250
When I bought mine the previous owner had it sitting on a rack, the top of which was was about 8 inches or so higher than the back of the truck. The side frames of the rack ran parallel to the truck sides so you could back under it, and the canopy sat on 2 x 4's that crossed from one side of the frame to the other. Once the truck box was backed under and centered under the rack you could climb into the box, lift the canopy slightly using your back and legs, and pull out the 2 x 4's one by one from the inside, lowering the canopy onto the box. Once completely down you could drive the truck out and fasten the canopy down.
Old Oct 13, 2005 | 04:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
Outdoor storage even if covered seems to hold moisture next to the unit which causes corrosion and mildew etc. If you are around anywhere that uses salt on the roads the problem gets worse. You can never really get the salt off.
Old Oct 13, 2005 | 08:20 AM
GLR's Avatar
GLR
I use some old saw horses and 2x4's, and have put poles in the ground set so you can back the truck between them, pick the cap up and slide 2x4 under the cap and hook to brackets on the post and drive out from under. I made one for my large wooden cap that I liked so well that I made it permanent for parking the lawnmower underneath.
Old Oct 13, 2005 | 10:34 AM
coatit's Avatar
coatit
Thumbs up
pulleys in the garage work best,
Old Oct 14, 2005 | 09:55 AM
2000silverbullet's Avatar
2000silverbullet
Up until not too long ago, I've always needed help getting my topper on and off my truck (which is even harder with the lift and tires). I figured out that if I took my tailgate off and got under the topper, I could squat it up off the bed rails and lay it crooked in the bed (one side IN the bed, other side propped up on the rails), then I jump out and slide it out until I can rest it on the ground, where my creeper is laying. Then I just lift off the other end and roll it into the garage. Once in the garage, I just lay it on it's side and strap some tie downs to the wall so it doesn't fall over. I know, not a clean process but it works for me.
Old Oct 16, 2005 | 08:43 PM
stroker2's Avatar
stroker2
Try this link:
http://andersonimprovements.com/hobb.../capkeeper.htm
Ziegelsteinfaust
2009 - 2014 F150
Aug 11, 2013 12:01 PM
cstrack
WTB - Parts & other
Aug 23, 2012 08:51 AM
Raven Rider
Jun 8, 2011 10:02 PM
Hawkdriver
Paint & Bodywork
Sep 16, 2003 07:47 PM
