Basic tranny question
Old Oct 12, 2005 | 03:20 AM
Harliquenn's Avatar
Harliquenn
I have an 82 F150, auto trans, 2wd. How do I tell what tranny I have in the truck. It should be stock, so does that mean I should have the C-6?
Old Oct 12, 2005 | 08:08 AM
Sycostang67's Avatar
Sycostang67
What engine do you have? I imagine you would only have a C6 if you have a 351 engine. One thing that separates the C6 from the C4 is that the C4 has a removable bell housing where as the C6 bellhousing and gearbox are one solid piece.
Old Oct 12, 2005 | 06:33 PM
rhodie's Avatar
rhodie
One easy way to tell is to look at the tranny pan and count the number of bolts and/or look at the shape of the pan. The c6 has an "s" shape at the rear of the pan, the c4 is square. I think the c6 has 16 bolts, and the c4 11. Can't check on my c6 to be sure of the number of bolts--it's raining out tonight--but someone else will hopefully chime in and correct me.
Old Oct 12, 2005 | 06:46 PM
smiller4597's Avatar
smiller4597
inside drivers door I.D. tag: bottom line of tag, trans G=C4, W=C5, K=C6. These letters are also stamped on a metal tag or plate on the tranny case or directly on the case itself
Old Oct 13, 2005 | 12:27 AM
Harliquenn's Avatar
Harliquenn
Thanks alot people.
Old Oct 14, 2005 | 11:17 AM
99mustang232's Avatar
99mustang232
went ahead and added this to my gallery for everyone to use
Old Oct 14, 2005 | 11:55 AM
mudgepondexpress's Avatar
mudgepondexpress
Is it a 3 speed or Overdrive model? I would venture to guess you actually have an AOD.
Kenny
Old Oct 15, 2005 | 08:08 PM
DBAPilotDad's Avatar
DBAPilotDad
I saw elsewhere that the G code was a C6?
