Got a small problem
Old Oct 12, 2005 | 12:04 AM
Fomoco_7's Avatar
Fomoco_7
Unhappy Got a small problem
Ok.... I took my 300 inline out of my 1970 f-100 and dropped a 360 from a 75 into it.. I have a 4 speed.. The trans from the 75 was a automatic.. i changed the bell housing attached a flywheeel and new clutch blah blah blah... But now that the 360 is sitting in the mounts the tranny is about 6 inches away from the enigine.... Is there kits for such a job? or is there a way to move the tranny forward... if anyone has encountered this problem please give me some ideas
thanks.
Your Friendly Ford Man
Fomoco_7
Old Oct 12, 2005 | 12:05 AM
Ford_Six's Avatar
Ford_Six
I think the perches need to be moved back.
Old Oct 12, 2005 | 12:12 AM
WillFordTruck's Avatar
WillFordTruck
I believe the perches are different for the FE V8 and I6. Go to a pick n pull and get the V8 perches.
Old Oct 12, 2005 | 05:51 AM
390fe's Avatar
390fe
I removed a 300/four speed from an old F250 and replaced it with a 390 automatic. I had to move the engine perched back towards the cab. If you dig around the crossmember, you'll find alternate mounting holes.
Old Oct 12, 2005 | 06:43 AM
jowilker's Avatar
jowilker
Fomoco, The perches were the same for the I-6 & FE back then, or they were in 66.
You have the bell mounted on the FE already??
Did you put a piliot bushing/bearing in the crank shaft?
John
Old Oct 12, 2005 | 02:39 PM
Fomoco_7's Avatar
Fomoco_7
ok ok i found the other mounting holes thanks i had to dig through about 2 inches of sludge.... poor old ford lol ill clean er up work in progress, oh and yes the engine came together with the tranny perfect
armydude
Aug 15, 2015 07:11 PM
hagerty_justin
Feb 5, 2011 07:12 AM
Hester007
6.4L Power Stroke Diesel
Nov 20, 2008 07:25 AM
Spiccolli
1983 - 2012 Ranger & B-Series
Feb 1, 2005 04:50 PM
herkdriver
Jan 3, 2002 08:13 PM
