Gauge help
Old Oct 11, 2005 | 11:50 PM
seawulff's Avatar
seawulff
Gauge help
I am going to replace the wiring in my '56 and I don't know if these gauges are stock. Can anyone tell me if these are add-on's or are they the stock item. I attached a photo using George's instructions so if it didn't work it's his fault not mine! Thanks for the assistance.
Old Oct 11, 2005 | 11:54 PM
sierraben's Avatar
sierraben
They definitely look aftermarket.
They look like Stewart Warner gauges, if those two letters on the bottom of the gauge dial are SW.
Old Oct 12, 2005 | 12:10 AM
51ford fan's Avatar
51ford fan
I have never seen any other gauges besides what comes in the built in instrument cluster on a factory built vehicle.
Old Oct 12, 2005 | 04:45 AM
54 gene's Avatar
54 gene
Not stock gauges go to www. midfifty.com they will have the gauges and cluster that you need.
Old Oct 14, 2005 | 10:22 AM
seawulff's Avatar
seawulff
If I descide not to use these gauges what do I do with the lines that come out of them, for instance the oil pressure line which connects to the engine block? The truck has the original in dash instrument panel, do I connect those same lines to the "idiot lights" in the panel or just cap them off.
Old Oct 14, 2005 | 03:35 PM
sierraben's Avatar
sierraben
I think the original oil pressure gauge in your 56 is electrical, not mechanical.
Are the wires from your gauge hooked up to the engine? It should be hooked up to a sender on the engine.
Does your original oil pressure gauge work when you run the engine?
If not, don't disconnect the aftermaket oil pressure gause, because that's your only means of showing you there is oil pressure in your engine.
Old Oct 14, 2005 | 03:42 PM
seawulff's Avatar
seawulff
The truck doesn't work at this juncture so I don't know if the other gauges work. The aftermarket one on there now seems to be mechanical I understand now that the original is electrical. What I don't have probably is the sending unit which connects to the block.
Old Oct 14, 2005 | 04:14 PM
sierraben's Avatar
sierraben
There must be a reason why the last owner installed the after market gauges.
Maybe the original gauges don't work, or .............
What is the first thing you plan to do with your truck? Get it running?
Old Oct 14, 2005 | 04:46 PM
AXracer's Avatar
AXracer
George's site has a wiring diagram. You can't hook the ammeter wires to the idot lites, it would likely blow it out. To remove the Ammeter, simply connect the two wires on the back to each other. The temp sender may work with your stock temp gauge. The oil pressure line would need to be disconnected at the engine and a oil pressure indicator (idiot) lite sender installed in it's place or the hole just plugged with a pipe plug.
Old Oct 14, 2005 | 07:20 PM
seawulff's Avatar
seawulff
Thanks for the input. The first thing that I have done to the truck is replace the brakes, shocks and front springs. I just finished tearing out the interior and derusting it and repairing some holes in the floor boards. My next project is to replace the wiring, distributor, plug wires, rotor and condensor and then try to fire it up. I contacted Sac Ford and they have a wiring harness and I can probably get the oil pressure sending unit from they too but I may leave those after market gauges in until I see how she runs. Thanks for the input.
Chris
Old Oct 14, 2005 | 07:40 PM
sierraben's Avatar
sierraben
seawulff, did you order a catalog from Sac Ford?
There free now, or at least mine was.
vintage-ford.com
Old Oct 14, 2005 | 08:10 PM
seawulff's Avatar
seawulff
I got mine awhile ago and it was free. Thanks
Old Oct 14, 2005 | 08:33 PM
sierraben's Avatar
sierraben
The dream book, huh?
Now where did I put those credit cards!
