78' Body Trim
Old Oct 11, 2005 | 09:32 PM
wkeller's Avatar
wkeller
Question 78' Body Trim
The trim on my 78' F-150 is starting to look pretty bad. It is starting to look really dull. My question is, was the trim actually chromed, (it is solid metal and does not have the rubber in the middle) or was it polished stainless steel.
Should I get a kit to polish it, or send it out to have it chromed?
Also, what do you call this trim option? I am assuming that the trim with the rubber in the middle is considered "racetrack" molding or do I have it backwards?
Old Oct 11, 2005 | 09:55 PM
MBBFord's Avatar
MBBFord
If the trim goes down over the wheel wells along the bottom of the truck and the normal chrome your talking about going along the truck at the top is "racetrack" molding.
I would prolly be easyest to just repolish it. It is hard to polish these aluminum pieces, but it can be done.
Old Oct 11, 2005 | 10:08 PM
wkeller's Avatar
wkeller
My truck has the chrome that runs inside the concave all the way down the side of the truck and it has chrom pieces that go over the wheel well arches. It doesn't have any other chrome pieces along the bottom.
So the trim is "aluminum"?
Old Oct 11, 2005 | 10:14 PM
MBBFord's Avatar
MBBFord
If you look at my gallery, my 77 F-100 has the racetrack trim package.
The trim is aluminum, but the chrome pieces that go over the wheel wells might be steel, I'm not 100% sure about those.
Old Oct 11, 2005 | 10:18 PM
ford390gashog's Avatar
ford390gashog
it is 100% aluminum it was polished at one time.
Old Oct 11, 2005 | 10:24 PM
roushracing617's Avatar
roushracing617
I believe MBBFord is correct, The trim running along the truck is definitely aluminum, and I think the wheel arch moldings are steel. Pollishing the aluminum is pretty tough, but if you do it, use a good wax or sealer on it when you're done. It'll help the shine last longer.
Old Oct 11, 2005 | 10:32 PM
wkeller's Avatar
wkeller
MBBFord, your trim is similar to mine except that mine does not have the rubber running down the center of the trim.
What would be the best way to polish it? I was thinking about possibly buying a kit from Eastwood, but if there is a better way, I'm all ears.
Old Oct 12, 2005 | 07:28 AM
MBBFord's Avatar
MBBFord
Buying a polishing kit would prolly be the best thing to do.
I polished my front grille with a drimel tool, buff *****, and a polishing compound, don't the easyest, or quickest way at all.
Some have even said to use a solivent to get rid of oxidation, and then go back and polish it, just another step(not really needed) to me.
Old Oct 12, 2005 | 08:03 AM
2tone73's Avatar
2tone73
Hey! Try a magic eraser and a little elbow grease. Remember wet the eraser first and wring it out. I think on the 78 and 79 the trim was made of steel and chrome. My 73 is all aluminum trim.
Old Oct 12, 2005 | 10:07 AM
MBBFord's Avatar
MBBFord
Nope, the trim is aluminum from 73-79. I wish it would be steel.
Old Oct 12, 2005 | 10:28 AM
wkeller's Avatar
wkeller
I've never tried the magic eraser. I think I've seen them at The Home Depot. I think I'll pick one up and give it a try.
If all else fails, can aluminum be chromed?
Old Oct 12, 2005 | 11:49 AM
2tone73's Avatar
2tone73
It can be polished!
Old Oct 12, 2005 | 09:40 PM
Mil1ion's Avatar
Mil1ion
The chrome trim is anodized
Check out the appearance forum for how to clean it up
Old Oct 13, 2005 | 10:23 AM
beartracks's Avatar
beartracks
Mil1ion is correct. The chrome trim (at least the race track style) is aluminum with hard anodized aluminum plated on it. It is very hard to polish.
Old Oct 13, 2005 | 02:54 PM
MBBFord's Avatar
MBBFord
You can take off the anodizeing with I think some type of sulfer.
