vacuum problems
Old Oct 11, 2005 | 12:28 PM
Bimmerboy1989's Avatar
Bimmerboy1989
vacuum problems
I have a 90 full-size bronco that I just rebuilt. My problem is that it idles a little high, and has no power. I have checked the timing, and its set to 10' BTC. I'm thinking it's one of the vacuum hoses, but don't know the exact way they were hooked up, if anyone could give me some pictures of the engine bay that would give me a good start. Thanks for all the help!
Old Oct 11, 2005 | 09:53 PM
TigerDan's Avatar
TigerDan
Which engine?
You really need a vacuum diagram for your vehicle, it's too hard to see proper hose routing from a pic.
You can try to find one online, but your best bet is to pick up a Haynes or Chilton's repair manual at just about any auto parts store. They have pretty good diagrams.
Old Oct 11, 2005 | 10:21 PM
Bimmerboy1989
Well, I have the vacuum diagrams figured out, but the truck still has no power. I will recheck ignition timing and pull codes tommorow.
Old Oct 12, 2005 | 03:31 AM
sierraben's Avatar
sierraben
Maybe with the engine idling, get a spray bottle filled with water and carefully spray water on the vaccum hoses and fittings and see if you notice an increase in rpms.
Keep the water away from the electronics, though.
It's just an old trick I use along time ago, to find vacuum leaks.
No guarantee though.
Spray at your own risk.
Old Oct 12, 2005 | 11:09 AM
Bimmerboy1989
Another trick I've used is a petroleum based product that is not harmful to rubber and checked for vacuum leaks. I'm gonna try that next.
Old Oct 12, 2005 | 12:36 PM
johneye's Avatar
johneye
which petroleum based product do you use?
Old Oct 12, 2005 | 07:18 PM
stevef100s's Avatar
stevef100s
Try a propane torch without being lit. I've never tried it, but I'm told it works.
Old Oct 13, 2005 | 08:42 AM
hatch_1989's Avatar
hatch_1989
Try this
I have used a spray can of ether also known as starting fluid or "hot shot".
Old Oct 13, 2005 | 07:15 PM
Bimmerboy1989
Well I haven't been able to work on it, I've been taking apart a 58 392 hemi, but the bronco is on my to do list so Thanks for the tips and I'll update this when I find out whats going on with it.
Old Oct 20, 2005 | 04:25 PM
Bimmerboy1989
Well I worked on it. I also found that all the vacuum hoses are shot. Any suggestions on what to do in this situation. The ford dealer doesn't sell vacuum lines for it anymore. Any suggestions would be greatly appreciated.
Old Oct 20, 2005 | 06:40 PM
TigerDan's Avatar
TigerDan
I'd say buy some bulk vacuum hose and replace them one at a time. You won't be able to use the neat Ford moulded-on connectors, but you can still stick the hose right on to the fittings.
Old Oct 20, 2005 | 08:14 PM
hatch_1989's Avatar
hatch_1989
Hard Lines
I intend to replace the vacuum lines on my E-150. I also found Ford cannot supply replacement plastic line.
As a substitute I am thinking about using small diameter steel tubing, brake line should do.
I probably will either paint the line color code on or with use colored shrink-fit.
The tubing will be attached with short lengths of vacuum hose. I have also seen some vacuum connectors at the local parts house that look almost stock.
Old Oct 20, 2005 | 08:24 PM
sierraben's Avatar
sierraben
What about using the tubing that they use for either air shocks or oil pressure gauges?
psychlopath
15
Sep 18, 2023 06:14 PM
danlee
Mar 21, 2017 08:25 PM
Ford59galaxie
21
Feb 12, 2016 05:29 PM
smith1978
30
May 27, 2015 02:26 PM
arnbobold
19
Jan 20, 2012 01:12 PM
