engine pulleys
Old Oct 20, 2005 | 08:54 PM
bremen242's Avatar
bremen242
engine pulleys
Quick question-
is the water pump pulley from a 302 interchangable with a 351w?? I have a 351W from an '85 F250HD, and it has a grove for the alternator, and then a serpentine part for a smog pump.
I want to swap it out for a normal 2 groove pulley, and was wondering if a 302 pulley will fit since I don't run across many 351s in the junkyard.
Also, I don't think this is they will, but will 302 accessory brackets fit on a 351? I'm guessing no since the taller deck, but wanted to make sure.
Old Oct 21, 2005 | 05:56 AM
ken75ranger's Avatar
ken75ranger
For the water pump I don't know. The accessories will fit if you buy- make some drop brackets that attach to the head.
They look like this.
351 drop bracket
