t98 four speed
Old Oct 11, 2005 | 09:33 AM
cbfomoco's Avatar
cbfomoco
t98 four speed
This may seem crazy but would it be possible or was there anything avalabe to attach or mate or aftermarket over drive for these tranies? I currently have one and would like to keep it but have over dive too. I know that the 3 speeds had over drive could one of these be made to work?? I also know there were the 5 speed overdrive that were in bigger trucks and i could look into that but, anyone know about the t98?? thanks
Old Oct 11, 2005 | 08:00 PM
flathead239's Avatar
flathead239
T98's
I looked into this at great length whilst building my 52 & unless things have changed you won't find much. About the nicest units I've seen are those made by Gear Vendors. They are basically an auxillary unit, build quality is outstanding- and so is the price- about $1500 last time I checked
My solution was to keep the T98, (love the whine too much) but get rid of the stock rear & swap in a Dana 60. It appears that the gurus of the site have compiled an interchange so check there for apps.
Jeff
52 F3
Old Oct 11, 2005 | 08:03 PM
Madathlon's Avatar
Madathlon
I also have a T98 and need highway speeds.. So I change out the 4.11 in my 9in rearend and put in a 3.25 and it works out great
Old Oct 11, 2005 | 09:01 PM
twilson's Avatar
twilson
i had a t-98 in an F5 and could not get the road speed. i installed a brownie aux trans but the engine didn't have enough power to overcome the 28% overdrive. i installed a 5 speed out of an 89 F-250. [ it was behind a 300 ]
i've had great luck with the setup. the drivability is much improved.
Old Oct 15, 2005 | 07:10 PM
Too Slow Monroe's Avatar
Too Slow Monroe
How hard is that to do? I am just starting this project and really need some highway gearing in our truck. I think I'm probably lower than 4.11s as second gear won't get me across an intersection without having to grab third...maybe the F250 was really geared down for farm work (and from the shape of mine, the farm got the best of it!)
I know, I need to run my VIN and find out what it had way back then...
Too Slow
Old Oct 15, 2005 | 07:32 PM
Madathlon's Avatar
Madathlon
Its works out well... I still use 2nd to start off.. This thread will help U alot https://www.ford-trucks.com/article/...ear_Setup.html
Old Oct 15, 2005 | 07:39 PM
sierraben's Avatar
sierraben
I have such a unit in my 81 F150, 4.9 L6 and T18 4speed.
It's a torque splitter that fits inbetween the bellhousing and trany.
Works great.
I'm not sure but I heard that there's very little difference between the T98 and the T18.
Weather or not it will bolt up to an older T98 and related bellhousing, I don't know.
My T18 front bearing retainer is 4.848 (basically the same as the opening in the bellhousing). I don't know what size the older trans are, though.
Old Oct 16, 2005 | 10:47 AM
1952henry's Avatar
1952henry
Depening on the year, your F250 ratio would be 4:56 or 4:86.
Old Oct 16, 2005 | 10:49 AM
Too Slow Monroe
Thanks Henry, that's what I'd figured...I'm going to start looking for gears soon.
ceetwarrior
28
Apr 28, 2013 03:25 AM
mexicoF250
Mar 16, 2010 12:53 PM
gover151
1983 - 2012 Ranger & B-Series
Nov 12, 2008 06:48 AM
sterling11
18
Oct 23, 2005 05:08 AM
Sixoh
21
Dec 10, 2004 11:17 PM
