rebuilding steering column
Old Jun 5, 2002 | 08:52 PM
Chu's Avatar
Chu
My steering shaft wobbles (non-tilt, 77 PU) in the column as I drive down the road, and I was wondering if there was a writeup on rebuilding it with new bushings and bearings. OR, can it just be tightened up somehow. If there isnt a write up, could someone go throught the steps to replace these parts? Im sure that there are others that have this same problem and you would be answering there Qs also
As always, thanks for the help guys.
Chu-man
Old Jun 5, 2002 | 10:06 PM
wildebeast's Avatar
wildebeast
try this number and order there catalog 18002225664 or order it at www.lmctruck.com they have alot of items you wont find anywhere else
Old Jun 6, 2002 | 01:47 AM
karljay's Avatar
karljay
I did mine a few weeks ago. 73 4x4 manual tranny. It has bearings on the top and bottom of the shaft that goes down the center. Yours should be simular
I started by removing the wheel, then found a few screws and nuts that hold down the center part where you have the turn signal/hazzard switches. these two nuts have a special bolt on the back side that can come loose and you'll have to reset them from the under side.
The center shaft has an upper and lower bearing that has a spring and nut at the top. I removed the outer shell and shaft then used come carb cleaner on the bearings and let it dry in the sun. I then packed the bearings with moly-graph greese and started putting it back together.
The bearings are ball type and usually can be cleaned and re-used. Packing is just like wheel bearings except small, I just used 1 finger to work the greese in.
I have an aftermarket wheel, but I've done this on the stock one before and the real trouble was getting the old wheel off. I used a puller and still bent several bolts until she came off.
I'd look at a few hours of work, not too hard of a job really.
Old Jun 7, 2002 | 03:51 PM
dfisher1's Avatar
dfisher1
All,
The trick to getting a steering wheel off is to load the puller to a critical tightness (as tight as you can get it) then take a hammer and strike the puller. The sudden shock will break the wheel loose. The way to tell if it is working is to see if you can tighten the puller a little more after striking it. You may need to repeat this procedure two to three times before the wheel comes loose.
There is also a C-clip on the column that holds the blinker assembly in place. Use an ice pic to dig it out. Becareful; I seem to bend mine and it always goes back in funny.
Good Luck,
My Way is the Highway,
KingFisher
Old Jun 7, 2002 | 04:10 PM
WC76TX's Avatar
WC76TX
bobbywheels1212
13
Oct 29, 2014 05:14 PM
4_whl_hvn
Aug 16, 2009 08:43 PM
Chu
Jun 22, 2002 11:21 PM
Chu
Jun 10, 2002 03:39 PM
Chu
Feb 10, 2002 03:31 PM
