rear abs sensor
Old Oct 10, 2005 | 08:09 AM
whistling69deuce's Avatar
whistling69deuce
rear abs sensor
i had to recently replace the rear in my 91 f150. i just replaced the whole unit with a used one which had been sitting outside for a while. i tapped side to side with a chisel to get the abs sensor loose after taking the bolt out of the top. it broke loss very easily. i then tried to gently pull the sensor out. which again happened very easily. then i looked in the hole and half the sensor was still in there. now. what is the best way to remove it. i was thinking about drilling a hole and threading it and using a puller but i think it is a magnet and will be hard as hell. anyi deas. the manual says just pull it out but mentions nothing of it breaking. thanks for any and all info.
Old Oct 10, 2005 | 10:01 AM
subford's Avatar
subford
It sounds like you need to change oil in it anyway, so just put a pan under it, slowly remove the back cover and drain the oil. Push the sensor out from the bottom with the cover off.
Old Oct 10, 2005 | 02:45 PM
whistling69deuce
i did change the oil in it. i changed it and then tried to remove the sensor. so i didn't really want to pull the cover back off if i couldn't get to the inside of the housing. i was thinking that the carrier was in the way and there would be no way to tap on the sensor to get it to pop out. i was just wondering if anyone has run into this problem and if i needed to remove the carrier.
Old Oct 10, 2005 | 03:00 PM
quicklook2's Avatar
quicklook2
in the manual it looks like you can tap it out, away from ring gear.
you will have to remove cover though.
Old Oct 11, 2005 | 08:26 AM
alz's Avatar
alz
Same thing happened to me when trying to hunt down a bouncing speedo. I was able to grab the outer metal shell with some needlenose pliers and just worked it out. I don't believe the magnet was left in mine, but you will probably have to get that out first. The new ones have plastic shells on them. Hope I could help.
edsheridan
Aug 25, 2014 02:39 PM
Layson
29
Jun 4, 2013 12:27 PM
beamundson
1997 - 2003 F150
Mar 28, 2012 04:23 PM
fordmerc
Oct 18, 2010 09:08 AM
