Sponsored by: Real Truck
Random Misfire
Old Oct 9, 2005 | 11:29 PM
NsaneSider's Avatar
NsaneSider
Random Misfire
Hello,I am having a rondom misfire on a 99 f250 v10.I have had the dealership run the tests,and all they can come up with is a random misfire...so my question is, Is there any way to test these! Can i buy just one and put it on and have it tested if it corrects it I would leave it, But if not can I put the org.one back on and move to the next one to try and determine which one it is.seeing that i have ten of these this is gonna cost me if you tell me i have to replace all of them! Anyone got any advice on this problem?????
Old Oct 10, 2005 | 07:02 AM
rwilimo's Avatar
rwilimo
That is real fun to find without the right equipment, any good dealer should be able to scope it with wds or pds/vcm and find the cylinder. Just running a simple eec test will not help you with this.
Old Oct 10, 2005 | 07:19 AM
FortyFords's Avatar
FortyFords
You must be talking about cop's ,yes you can buy one and move it around.
If you have a DVM(digatal volt ohm meter ) you can measure the resistance of the coil.Best to do it when its hot,this is when they break down.
You may also have a bad sparkplugboot that is alowing the secondary ignition to short to ground or even a sparkplug itself.
Have the sparkplugs ever been changed?
You could have a dirty fuel filter or a bad injecter or dirty injecter
If you can't do any of this find a different dealer or an independent mechanic.
Rich
tailbone
2004 - 2008 F150
Mar 11, 2013 08:43 AM
Methodical_1
Feb 15, 2013 12:11 AM
fteduran
Jun 24, 2011 07:48 AM
trucktech
Modular V10 (6.8l)
May 30, 2011 08:34 AM
Timba
1997 - 2003 F150
Jul 4, 2009 09:49 AM
