1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Random Misfire
Old 10-09-2005, 11:29 PM
NsaneSider's Avatar
NsaneSider
NsaneSider is offline
Random Misfire
Hello,I am having a rondom misfire on a 99 f250 v10.I have had the dealership run the tests,and all they can come up with is a random misfire...so my question is, Is there any way to test these! Can i buy just one and put it on and have it tested if it corrects it I would leave it, But if not can I put the org.one back on and move to the next one to try and determine which one it is.seeing that i have ten of these this is gonna cost me if you tell me i have to replace all of them! Anyone got any advice on this problem?????
Old 10-10-2005, 07:02 AM
rwilimo's Avatar
rwilimo
rwilimo is offline
That is real fun to find without the right equipment, any good dealer should be able to scope it with wds or pds/vcm and find the cylinder. Just running a simple eec test will not help you with this.
Old 10-10-2005, 07:19 AM
FortyFords's Avatar
FortyFords
FortyFords is offline
You must be talking about cop's ,yes you can buy one and move it around.
If you have a DVM(digatal volt ohm meter ) you can measure the resistance of the coil.Best to do it when its hot,this is when they break down.
You may also have a bad sparkplugboot that is alowing the secondary ignition to short to ground or even a sparkplug itself.
Have the sparkplugs ever been changed?
You could have a dirty fuel filter or a bad injecter or dirty injecter
If you can't do any of this find a different dealer or an independent mechanic.
Rich
tailbone
2004 - 2008 F150
03-11-2013 08:43 AM
Methodical_1
1997-2006 Expedition & Navigator
02-15-2013 12:11 AM
fteduran
06-24-2011 07:48 AM
trucktech
Modular V10 (6.8l)
05-30-2011 08:34 AM
Timba
1997 - 2003 F150
07-04-2009 09:49 AM
Quick Reply: Random Misfire
