Sponsored by: Real Truck
rust
Old Oct 9, 2005 | 05:42 PM
allis327's Avatar
allis327
Unhappy rust
I live in Minnesota and they use alot of salt on our roads so this maybe a unique problem. ON my 2000 F250 the drivers side rear door there was peeling paint and rust under the rubber seal on the bottom of the door. I removed the rubber from all the doors and only had the one bad spot. There would have been more next year because even when I wipe down the doors and jambs after a wash there is still dirt stuck under the rubber. Something to think about because rust sucks.
Old Oct 9, 2005 | 06:44 PM
350z's Avatar
350z
Thumbs up
Check out Eastwood Company excellent rustproofing products , I used the brownish gold undercoat on my entire truck , excellent product !
Old Oct 12, 2005 | 01:47 PM
Fat Diesel's Avatar
Fat Diesel
The #1 spot to check is your oil pan. Quotes from the dealer to replace run from $1400-1800. They rust through and the dealer has to pull the engine and turn it upside down to replace it... I HATE RUST !
Old Oct 12, 2005 | 09:31 PM
99f350sd's Avatar
99f350sd
Use Rust Bullet... Check it out best stuff around.. I Hate rust worse..
Old Oct 13, 2005 | 12:08 PM
Fat Diesel's Avatar
Fat Diesel
I'm sure you guys do hate it worse. My pan has 170,000+ on it and has zero rust, only a couple of spots where the clear coat is peeling a bit. But I have been working some rust off a 351W block I got from a boat... Navel Jelly works pretty good if you leave it on long enough.
Have any of you guys tried a rust converter that chemically converts the rust into a paintable polymer? I used some on the floor of the Falcon and it works pretty good.
Old Oct 13, 2005 | 12:30 PM
SLE's Avatar
SLE
I learn something new every day; I've never heard of a oil pan rusting through though.
I live in ND and your MN salt seems to work its way across the river. even when I wouldn' drive on the MN side for weeks at a time my car would be still be white with the salt residue although it could be a city thing to. in the midwestern part of ND they use a mix of salt, gravel, and some byproduct from the coal plants. I don't think the salt content is all that high but the leading edge of your hood takes a beating from the gravel and the black coal residual really reminds you to wash your car, you don't want to lean against the car if you've been on a recent hwy trip.
Old Oct 13, 2005 | 08:19 PM
wolfbike1500's Avatar
wolfbike1500
I had the same problem as allis327 to the letter. I used this stuff called "Extend"? (I think). It is a permatex product. It supposedly converts rust to a paintable surface. Well, I scraped the loose stuff off and sprayed this stuff on as directed. It seems to have worked. The rust has not come back. I have not painted it yet since it cannot be seen unless the door is open, so I can see very clearly that no rust has reformed. I recently got some Rust Bullet as recommended by other threads in this forum to use on my rusting rear diff cover. I really really hate f-ing rust....
Old Oct 13, 2005 | 11:55 PM
99f350sd's Avatar
99f350sd
Rust bullet works best when used as a primer over sand blasted metal. Second best is to use a needle scaler then 2 coats. Top coats help also any paint will do.
Extend doesn't work not one bit. The only thing I have found to work in over 35 years of battling rust is RB. You must remove all loose rust or it will fail over time. Stir everytime you use it or it will fail also. If anyone has any questions please email me and I will be glad to answer any questions or share my experiences with you.
I don't sell the stuff.
Dick
cassenbl
Aug 2, 2012 10:04 AM
Eric H
Feb 9, 2011 04:36 PM
fordboy67
Jan 27, 2008 09:51 AM
audimaster
18
Jul 17, 2007 12:38 AM
pj2
1983 - 2012 Ranger & B-Series
May 15, 2003 02:29 PM
