240 timing issue
Old Oct 9, 2005 | 08:36 AM
wk65's Avatar
wk65
240 timing issue
I have a 66 240 that I have only had for 6 months. Still not tagged till I get the last bugaboo worked out. I have good cylinders as I had to put 6 new pistons in due to 1 broken piston. I did this in chassis so I did not have the whole engine apart. I did add duraspark 2 and rebuilt the holley 1940 1V carb. My ign timing will not allow the engine to run within the marks on the cover. I must rotate the distr. to about 1 oclock which is not even close the the scale on the cover. When I do this the vac increases and the advance puts the mrk at about 12 oclock. I verified TDC and my original damper mark lined up perfect. I am ready to pull the cover off to verify the cam timing as I think something is off. This is a ford reman with low miles. Anything can happen but wanted some support before I go forward. Weird one to say the least!
Thanks
WK65
300zx
24
May 10, 2016 12:43 PM
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
deputydog03
1997 - 2003 F150
Dec 11, 2013 01:45 PM
fordguy76
Jan 5, 2007 01:53 PM
snapper1
Apr 18, 2003 01:23 PM
