hey everyone im new to this so i thought i would try it. well i just got a 74 ford courier from my uncle and well i got it running but it isnt charging, i just changed the alatnator, bought a new battery, and just got the voltage reguletor to be the right one, and well it still isnt charging and was wondering if anyone here can help me. any tips, or problems solving ideas would help
thanks
i know that there are seven wires coming out of the regulator, and the colors are in abreviation as follows. w-r, w-b, y-g, b-y, b, and finally w. and then a blue wire that goes to a condensor. ill have to get back to u on the altanator wires and colors.
Is there any letters next to where the wires are hooked (A,I,S,F) ?
Does b = black or blue
the b is black. and i just got the altanator checked today and well it seems that they sold me a bad altanator to begin with unless my truck did something to it. but im not sure. so anyways ill keep u all posted on this when i get my new altanator and battery
thanks again
If you get it all hooked back up, and it still doesn't charge, see if you have voltage on the "f" terminal when it's running.
Before you do that, measure the battery voltage with the truck off. Then measure it with the truck running. It should be higher when the truck is running, hopefully around 14 volts. That will be a quick way to see if it's charging or not.
