location keyless remote module 94 Bronco
Old Oct 11, 2005 | 01:57 AM
fordtrucksforever's Avatar
fordtrucksforever
Anyone know where this module is located. I purchased a Bronco in not running condition and it didnt come with the remote. I found out the hard way after unlocking the door that it has the factory anti theft. Have a remote now but need to program it.
Old Oct 11, 2005 | 07:17 PM
Franklin2's Avatar
Franklin2
is this the one where you turn the ignition on and off 8 times, and then hit the key fob and it programs itself?
Old Oct 12, 2005 | 12:17 PM
charlez's Avatar
charlez
To program (or re-program) transmitter(s) into the electronic door lock control, perform the following steps:
1. Turn the ignition switch to the ON or ON/ACCY position and short the two terminals of the program connector (J2), a two-pin connector located below the driver's side of the instrument panel (04320) at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each transmitter, (one at a time). All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same transmitter). If the door locks still fail to respond, go to «PINPOINT TEST D» .
3. Repeat Step 2 to program additional transmitters into the control module (up to four transmitters maximum).
4. Turn ignition switch off. All doors should lock and then unlock.
5. Make sure the short has been removed from the program connector J2.
