tunner question
Old Oct 8, 2005 | 11:47 PM
unluckylow's Avatar
unluckylow
tunner question
With a tunner will the SES light come on due to over boosting the pcm setting. Just curious cause I dont think I can even hit 25psi with the tunner set on its highest setting, also with the tunner I get some weird problem where I accelerate hard and as the RPMS climb I seem to loose power for a few seconds and then its back. Also Ive heard in with the stock program if you unhook the red line going to the wategate you should get an SES light...not my truck I can barely hit 20psi under hard acceleration.Any ideas and I get no codes at all.
Old Oct 9, 2005 | 07:44 AM
johnny8's Avatar
johnny8
hmmm.... that doesn't sound right.... even with my predator set on the 40hp tow tune i can get over 20lbs of boost pretty easy... and with the 85hp tune loaded she goes right to 24lbs of boost FAST...! and FAST is what my truck goes at that point... sounds like you have a fuel problem somewhere... maybe fuel pressure...
Old Oct 9, 2005 | 09:46 AM
Kwikkordead's Avatar
Kwikkordead
I agree with Johnny8. My truck will hit 28 on the 60 HP setting SES light on and everything. So far I haven't experienced the dreaded "defuel" that everyone says happens.
I recommend putting the truck back to the stock setting and then do some diagnostics. Fuel pressure at WOT not just idle. It needs to be at least 55 psi at all times.
Another thought, a problem with the HPOP, but that would make very hard starting, engine hot, which you haven't mentioned so I think that's less likely.
Get the foundation proper and then add the tune.
Old Oct 9, 2005 | 11:02 AM
unluckylow's Avatar
unluckylow
The truck starts fine and seems to run fine with no tune, I did down load the newest update for the tunner and I will see what I get..also on my way to work I'll bug in the tunner and see if it reads fuel pressue and I'll monitor it and see if it stays around 55psi.
Old Oct 9, 2005 | 11:27 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Actually, you have. When the PCM defuels, it basically just holds where it is. There is no huge power loss, it simply stops the fueling table at the point the light comes on.
Once you defeat the SES light and feel your actual top end power you'll see what I mean.
Old Oct 9, 2005 | 12:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yeah i had the same problem. after putting my dual relief valve in, i volunteered to use my truck to haul my dad's 6000 lb skidloader and trailer. i drove on setting 2 (tow, on the edge), and i drove in OD off. crossed a bridge under construction, at about 2250 rpm. then i gave it alot of pedal, to gain my speed back up the hill. it just hissed loudly (from the filter) and bogged down. it did not shift down, but rather bogged to about 1750. the monitor read 850*, about 13 lbs of boost. only 13 lbs! it didnt seem right, i thought that thing would shift and walk up that hill like nobody's business. i am going to change my fuel filters, to start. the SES light still came on though.???
Old Oct 9, 2005 | 10:06 PM
Kwikkordead
AAAAAAHHHH I see. I thought a defuel was a massive loss of power. Not a plateau. Looks like a boost regulator is in order.....
Old Oct 9, 2005 | 11:46 PM
wildbill1963's Avatar
wildbill1963
Check and see what codes got stored before you make any changes. I do not believe you are setting a high boost code. Let us know what you find out.
Old Oct 9, 2005 | 11:50 PM
wildbill1963
Where are you reading boost from, and if you are reading from MAP line, is anything else connected to that line. Something doesnot sound right. You should be able to get more boost. Check and see if there any codes set in your PCM to better pinpoint your issue.
Old Oct 10, 2005 | 07:43 AM
johnny8's Avatar
johnny8
i have the dual relief valve setup... no more overboost defueling issues... but i do get the exhaust pressure too high code every so often... sounds like a 5" system is in order...! any opinions as to wether or not one of those will cure this backpressure problem..?
Old Oct 10, 2005 | 08:17 AM
Kwikkordead
It might help, but the sensor is still on the upstream side of the turbocharger.
I noticed that the engine revved up a lot easier with the new system.
Old Oct 10, 2005 | 08:44 AM
johnny8's Avatar
johnny8
well... that doesn't seem to be a problem... the ses light comes on and stays on for awhile but it doesn't seem to power the engine down when it happens... and if i get this ww on today i will loose a couple of lbs of boost anyway so i won't see that condition as much, and i don't see it very often now... only when i'm playin'...!
Old Oct 10, 2005 | 09:11 AM
wildbill1963
If you are getting a P0478, then that can be cured as well. Let me know! the 5" will not fix that issue. Your problem could be the EBP Sensor (behind your tensioner pulley) is getting pluged.
This is a typical problem with these trucks, when you run a chip of any kind. Soot gets in the pipe.
Old Oct 10, 2005 | 09:59 AM
HeatStroked's Avatar
HeatStroked
If the EBP sensor is clogged or bad, a EBP senor bypass is available from an on line vendor.
Old Oct 10, 2005 | 10:48 AM
unluckylow's Avatar
unluckylow
Yeah I have the gauge comming off the MAP Sensor line, thats the only thing I have hooked to that. And I get no codes at all not even the ones that a they say a tunner should give you just because its a tunned vechicale. I do get one code but its for the IAH, it says low voltage but I did the IAH delete so the IAH isnt even there. Im still stumped. Like I said Ive never had the SES light come on even with the tunner set on the highest setting.
