performance lighting for Aerostar
(PS: you can go to their site and see what they look like)
Thank you for your interest in EuroLights(tm).
EuroLights bulbs are designed as direct replacements and offer maximum
performance, output, & appearance.
EuroLights true high performance bulbs for your Aerostar are Type9007 for
headlights low/high beams.
Prices are as follows:
Type9007 -Xenon-Charged Blue/White:$45.00 per pair (Super High Output)
Type9007 -Blue/Gold SuperBright Ion : $34.00per pair (Super High Output)
Type9007 -Yellow SuperBright Ion : $34.00per pair (Super High Output)
All units are in-stock & ready to ship!
FREE Shipping! - Limited time offer.
***Special Offer***Orders of 2 or more pairs: we can offer you a $10.00
discount. Mention code #3851 when ordering to receive this discount.
(limited time offer)***Special Offer***
All models above are direct replacements for your factory bulbs...easy
install.
Here are the differences:
Xenon-Charged Blue/White: True high output & optimized gas mixture
offers dramatically increased performance over factory bulbs and projects
pure white light onto the road and appears blue/white in the housings when
lit. Maximum Performance!!
Blue/Gold Ion: Ion coated bulb produces a dramatic SuperBright blue/gold
light. Appears blue/gold in the housings & projects blue light onto the
street. Coating increases actual brightness 25%.
Yellow Ion: Ion coated bulb produces a dramatic SuperBright yellow
light.Coating increases actual brightness 25%.These units offer high
performance increase especially in harsh weather such as rain, fog, snow.
All EuroLights are backed up by our----90 Day free replacement warranty.
dual beam all in one headlights are a compromise for beam angle and focus.
we have 1000 lb elk here, will definitely crumple a grille.
To get a true improvement in lighting, you need a better beam pattern then the Aerostar lenses can give. They scatter too much of the light output and do not put light in the places on the road where it is most needed. You can put higher wattage bulbs in, which will help a little, but they will simply scatter more light.
The only solution I've found to improve headlight output is to retrofit the flush-style headlights with the earlier sealed beam lamps, then replace the sealed beams themselves with an H4 bulb conversion lamp, like the ones that Hella makes. I pulled all the parts I needed for this from a junkyard fairly cheaply. I have the Hella lamps in another car in my garage that I can "borrow" from. I just haven't yet had the time to put it all together. I did, however, switch over the sealed beams in my Capri and it made a huge difference. I used stock wattage bulbs, but the improvement comes from a better beam pattern that doesn't scatter and waste nearly as much of the light output from the bulb. These lights also respond quite well to wattage increases because of the their better beam pattern.
Of course, you can also mount driving lights, which are always a big help. I also have a pair of IPF lights (6.5"x8.5") that I've also been meaning to install. I just haven't come up with a good way to mount them (they are fairly heavy and need a beefy mount)...
Just my $0.02...
BTW, many online retailers and manufacturers have aitomated response systems. They don't add to the cost, rather they lower it.
ge high output sealed beam
bosch h4 sealed beam conversion
both headlamps replaced
huge improvement over the ge high output sealed beam. much better spread of beam, and most of the beam intensity is focused toward the road. so the beam is not wasted lighting up trees.
the bosch version i bought is E-code - meets european requirements and hence you see the sharp cut-off. dot does not have such requirements and hence you see the blotch of light.
by the way, the bulb i used in the conversion is a regular osram h4 bulb. tho in the pic it looks purply, its actually the typical halogen yellow.
I should take similar pictures with the lights on the Capri. FWIW, on that car, the lamps are the smaller 165mm rectangular type rather then the 200mm ones the Aerostar uses because of its pop-up headlamps. In that size, Hella makes a "Free Form" lamp aas well as a traditional parabolic. On these, the reflector has a unique, computer modeled shape to gather a greater % of the bulb output compared to a simple parabolic reflector shape.
Generally, Free Form lamps are 45% efficient rather then 35% for a parabolic lamp. Doesn't sound like a lot, but keep in mind that about 50% of the bulb output goes forward, away from the reflector, and the reflector can only work with the half that goes backward. So a reflector probably cannot exceed 50% efficiency without wrapping around ahead of the bulb (like a projector beam reflector does). Anyway, the marketing department says this about the FF lamps:
guess they charge that much to pay for that automated response system.
