97 Explorer high mount brake light
Old Oct 8, 2005 | 07:32 PM
ottosmom's Avatar
ottosmom
Angry 97 Explorer high mount brake light
Looks like my high mount brake light is dead. I have the sealed one that says "take to the dealer and bring some vaseline", and $300 is NOT an option. I am now looking into universal LED brake light kits. How easy are these to hook up? I am guessing that there is a plug somewhere under my rear bumper that I would use on a trailer. Any advice on what I should be looking for? Recommendations on which light I should buy? Any info would be greatly appreciated.
Old Oct 8, 2005 | 09:13 PM
don96exp's Avatar
don96exp
The high mount stop light is neon that runs on high voltage AC current. Most time the power pack (inverter). I replaced my and that solved the problem. Costs around $90 for the part, it's located on the inside of hte back door under the inner trim at the top. Good luck.
Old Oct 10, 2005 | 08:26 PM
jdmattsland's Avatar
jdmattsland
high mount on 95 explorer limited
my light works for around 5 mins after 1st start of the day, after that it dies,
by changing the part you mention fix my explorer, 95 limited.
thanks, jdmattsland..........
shargue
Electrical Systems/Wiring
Aug 13, 2017 07:38 PM
12engine
Jan 12, 2017 02:48 PM
12engine
Jan 12, 2017 09:56 AM
59203shop
Apr 17, 2016 11:22 PM
KawiG5
1978 - 1996 Big Bronco
Apr 3, 2009 02:29 PM
