Sponsored by: Auxito
odometer problem
Old Oct 6, 2005 | 05:17 PM
Wit-in-MN's Avatar
Wit-in-MN
odometer problem
I have a 2000 F 150 4x4 ex cab, and every now and again after starting the pick up the odometer won't come on. Sometimes it will even take a few mins to come on. Anybody have any suggestions?
Old Oct 6, 2005 | 07:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Old Oct 6, 2005 | 08:50 PM
steve(ill)'s Avatar
steve(ill)
yep. there is a cold solder joint on the back of the dash board circuit board. i had it 6 weeks ago and followed the directions and photos on this board and fixed it. took about an hour and half to get apart, solder, and reinstall. i dont remember the exact post. i will look. had it ear marked for a month, just deleted it yesterday.
Old Oct 6, 2005 | 08:55 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com//forums/...meter+blackout
Old Oct 7, 2005 | 07:50 AM
Wit-in-MN's Avatar
Wit-in-MN
Thanks any help is greatly appreciated.
Old Oct 30, 2005 | 08:35 PM
Mike-G's Avatar
Mike-G
Hey all,
I will likely tear into this project around the Christmas timeframe. This post makes it look pretty easy. One question though, my shop manual has the following note "NOTE: Following installation of the instrument cluster, reset the PCM ID and carry out the PATS parameter reset procedure. Refer to Instrument Cluster Parameter and PCM ID Reset Procedure in this section." I didn't see any mention of this in anyone's posting. Can someone enlighten me on what is involved. My manual is pretty weak on this detail. Thanks for your help (as usual).
Mike-G
Old Oct 30, 2005 | 10:55 PM
steve(ill)'s Avatar
steve(ill)
i think the computer checks to see if someone has switched the dash panel with a lower miles readout?? ect. as long as you fix the board and put it baack in the same truck, there is no PATS problem.
