Sponsored by: Auxito
vibration
Old Oct 29, 2005 | 05:57 PM
shivelyt's Avatar
shivelyt
Unhappy vibration
I have a 99 F-150, 2WD with 100,000 miles. I noticed a vibration a couple of day ago, so I replaced both u-joints today. Now the vibration seems worse than before. The faster I go the worse it gets. I made sure the drive shaft went back in the splines the same way, but I wasn't sure how critical that was. Anybody else experience something like this? It really came on quick.
Old Oct 29, 2005 | 06:46 PM
steve(ill)'s Avatar
steve(ill)
i think i would jack up the front end and check the ball joints and tie rod ends. then i would jack up the back, in neutral and rotate the drive shaft and feel/listen to the shaft and rear axle bearings.
Old Oct 30, 2005 | 03:20 AM
code_red's Avatar
code_red
If you could describe the vibration a little more, im sure that someone would be able to help you get a pin point on exactly what it might be.Any noise's? Tires ok and balanced?? The more info the better your chances of getting the correct response.
Old Oct 31, 2005 | 06:22 AM
shivelyt's Avatar
shivelyt
Talking
Found the problem. The emergency brake cables weren't releasing the rear brakes completely. Apparently the previously owner never used them. I used them at a boat ramp about 4 days ago and thats when the problem started. Thanks for the responses.
