deep creep cleaning question
Old Oct 6, 2005 | 02:30 PM
puck1263's Avatar
puck1263
I saw on one of the threads the other day to give your intake a deep creep treatment. I did everything, except the thread said to unhook a vaccuum tee going into the intake and suck up about 4oz into the intake. That should clean all the parts of the intake that are otherwise inaccesable. Can someone who knows this post a pic of the tee in question?
Old Oct 6, 2005 | 02:48 PM
MemOrex's Avatar
MemOrex
You can use the Brake Booster vacuum line.
low92flareside's Avatar
low92flareside
I'm not sure of the tee they're refering too although I've seen in mentioned in the forums before. When I clean out mine, I pull the vacuum line from the brake booster and shoot it in thru there.
Old Oct 6, 2005 | 10:32 PM
MRL123's Avatar
MRL123
Somewhere on your intake manifold, or plenum, if you prefer, there is a vacum tree with various sized rubber llines attached to it. Follw the largest of these, which should be you brake booster line, unhook it from the booster and shoot the "treatment" down that vacum line with engine vacum applied. This will suck the spooge into the intake and clean it up as advertised.
Good Luck!
Cheers!
Mike
Old Oct 8, 2005 | 05:14 AM
Jack01's Avatar
Jack01
center of your plenum right hand side facing the engine from the front of your vehicle. you will find the vacuum boster line coming from here there will be a line coming off for your Air condioning controls/ heat a line for the pvc valve and one line plugged with a cap
widebody95
Aug 23, 2011 09:08 AM
pile_53574
Jul 16, 2011 11:27 AM
Lanny Sutton
Nov 3, 2008 09:48 PM
rds4ou
Jan 20, 2007 04:03 PM
SeannyBoy84
Modular V8 (4.6L, 5.4L)
Sep 12, 2005 03:25 AM
