need help asap
Old Jan 20, 2007 | 08:56 AM
rds4ou's Avatar
rds4ou
Arrow need help asap
recently my x has had a little bump to its idle not much just a little. I think i read on this forum that sea foam has a product called deep creep that you spray into the t.b when its running and it cleans the intake system. I did this last night by the direction and this morning my x has a big idle problem now. It killed itself once and sounds like has a slight miss. Has anybody used this and had a problem? Could using this product have fouled my plugs the wires and coil pack have spark. The plugs and wires were changed about 15000 ago. Quick help would be nice i have to take the x on a trip tomorrow.
Old Jan 20, 2007 | 11:59 AM
MisterCMK's Avatar
MisterCMK
Is it setting a check engine light?
Check your IAC and check for any vac. leaks.
Old Jan 20, 2007 | 12:26 PM
rds4ou's Avatar
rds4ou
no mil is on i cleaned the iac last night as well. Before i cleand the iac it sounded like there was air coming from it. This morning there didn't sound like any air.
Old Jan 20, 2007 | 01:43 PM
MisterCMK's Avatar
MisterCMK
Make sure that the gasket is still good on the IAC and like I said, check for vacuum leakes
Old Jan 20, 2007 | 01:53 PM
mrshorty's Avatar
mrshorty
What year Explorer? If '96+, which engine?
Old Jan 20, 2007 | 04:03 PM
rds4ou's Avatar
rds4ou
i have a 2001 sohc
Ranger Bob
1983 - 2012 Ranger & B-Series
36
Oct 31, 2019 05:05 PM
bluethundersowner
Nov 16, 2013 11:24 AM
jpalladino
1997 - 2003 F150
29
Jan 16, 2012 11:41 PM
thunder31634
Feb 27, 2010 12:31 PM
MeBadDog2002
Electrical Systems/Wiring
Aug 29, 2004 09:58 PM
