How do drain the Power Steering Pump??
Old Oct 5, 2005 | 03:31 PM
Komputersman's Avatar
Komputersman
I would like to drain, clean and refill my power steering pump. My fluid is looking bad (burnt look) anyways how do I do it. Do I disconnect a line and let it drain out? If so which one?
Thanks
Old Oct 5, 2005 | 03:39 PM
ford390gashog's Avatar
ford390gashog
ok there is a line that runs to the back of the unit it is a low pressure line held on by a screw clamp the other is high pressure which uses a hydraulic hose. remove the low pressure end and place it into a container , put a funnel in the dipstick tube have someone else start the truck and add fresh fluid until the fluid coming out is bright red then stop shut it off reattach the hose and add more fluid as needed. done
Old Oct 5, 2005 | 03:44 PM
Komputersman
Cool that sounds easy enough. I thought I rememberd something about a low pressure line.
Thanks.
Old Oct 5, 2005 | 03:47 PM
ford390gashog
use type f transmission fluid.
giorgio.fo
May 31, 2014 10:10 PM
RIKIL
Nov 16, 2012 04:53 PM
fin reaper
Sep 8, 2012 04:39 PM
Spades
Aug 11, 2010 10:32 AM
Dasvigo
May 15, 2009 08:11 PM
