Fuel additive
Old Oct 4, 2005 | 08:38 PM
redrock233's Avatar
redrock233
Fuel additive
Was just wondering if any one has heard of putting acetone in your fuel tank. I had heard about it at work and looked it up they say to add 1-2 OZ to every ten gal. just not to sure if it works or not.
Old Oct 4, 2005 | 09:01 PM
olfordsnstone's Avatar
olfordsnstone
Don't know as I have never personally heard of that. I do know that these later high tech engines are particular about what you do with the fuel. I would ask the Ford Dealer about that before using it to ensure that you dont have warranty issues in the future.
T
Old Oct 4, 2005 | 09:32 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
I would not use it!!!!!
Stay with a good quality, name brand diesel motor rated additive that adds the lubricity your fuel pump & injectors need and the cleajning agents as well. Acetone will only clean and I am sure is not a proven use item... why risk it????
I use Powerservice year round in every tank and have no problems. Others standyne and have no problems... but hey, give it a try (on your truck) and let us know... but I will never use it. I have enough "other issues" to worry about on my truck to skimp on using a "new wonder cure".
Jeff
Old Oct 10, 2005 | 12:14 AM
jeffchickering's Avatar
jeffchickering
Exclamation
Im trying it now with my 98 f250. Heres some info on it all...
Acetone as an additive in your fuel
Old Oct 10, 2005 | 03:24 PM
redrock233's Avatar
redrock233
So how is the truck doing since you started to use it.
Old Oct 10, 2005 | 03:34 PM
jeffchickering
I just started last week, and havent had the chance to drive more than 10 miles so far. I will post my findings as soon as possible.
Old Oct 14, 2005 | 02:18 PM
nieking's Avatar
nieking
Here are a few more good links about using acetone with fuel.
http://peswiki.com/index.php/Directo..._Fuel_Additive
www.smartgas.com
Old Oct 14, 2005 | 04:01 PM
Mustang42's Avatar
Mustang42
I have heard that using too much acetone can actually hurt your mileage. Although, I don't recommend using it. I say just use a good additive like Power Service or something similar
Old Oct 14, 2005 | 04:34 PM
4S FED's Avatar
4S FED
I have been curious as to what additives everyone is using. Also, where do you buy the additive that you use? Are truck stops (Pilot, T/A, etc.) a good place to find different brands? Does Shell make a good Fuel Additive?
Old Oct 14, 2005 | 04:44 PM
Customz's Avatar
Customz
It will eat your fuel lines and any other seals it comes into contact with...probably worth it for the amount of fuel you're saving.
Old Oct 14, 2005 | 05:36 PM
Sarge261's Avatar
Sarge261
I agree wuth beachbumcook, you can try on your truck, but thats a pretty big gamble. If you do have a fuel related problem and FoMo does a fuel sample and has it analized and find that you have added a non-recomended additive then you will be liable for repair costs, parts and labor. I would say to use a fuel additive that is recomended for diesels. I also use power sevice all year round, white bottle in the winter and silver bottle in the summer. It treats 300 gallons and it is available at walmart for 10.00. Others use the standadyne because it is accessable to them. They are both great additives. Let us know how you make out and good luck. Do your research and pay attention to how much you add. My buddy was using it on his Duramax and it ate the seals around the injectors and the seals where the fuel lines connect to the tank. For me I will go to walmart and use a product designed for the fuel. Its cheap insurance.
Sarge
Old Oct 14, 2005 | 07:06 PM
kw5413's Avatar
kw5413
Go here and / or do a 6.0 forum search on "fuel addtives":
https://www.ford-trucks.com/forums/s...fuel+additives
Old Oct 15, 2005 | 09:28 PM
jeffchickering
as far as homework is concerned.... look at the ingredients to all of your over the counter stuff..... its usually.... acetone..
and other "stuff"
