Starting Problems
Old Jun 18, 2002 | 02:48 PM
lt dan's Avatar
lt dan
Starting Problems
I have a 1970 F250 W/360, auto trans, origional. When I turn the switch key to start, the red light beside the switch comes on, but the starter does not engage. I have a fully charged battery, I can start the it by grounding starter "cylinoid" to positive battery post with switch in the "on" position and it will start and run. I have replaced the "cylinoid" and have the same problem. Can anyone recommend a repair, or identify the problem. I know there is one nut loose behind the steering wheel.
Old Jun 18, 2002 | 02:56 PM
Big Bad 1Ton's Avatar
Big Bad 1Ton
Starting Problems
are you getting power to the S terminal of the solinoid? If not check for a broken wire between the solinoid and the switch.
Old Jun 18, 2002 | 03:18 PM
Mil1ion's Avatar
Mil1ion
Starting Problems
1st :It is spelled Solenoid
What do you mean Grounding the it to the battery ?
It should be power wire from + post of battery to the S terminal.
You need to have power to the *S* terminal of the Solenoid to get it to actuate the starter.
The trouble is caused by the wiring or even the ignition switch.
[font color=red]Dennis
Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jun 18, 2002 | 03:32 PM
Big Bad 1Ton
Starting Problems
as long as it runs does spelling matter?
Old Jun 18, 2002 | 03:44 PM
Mil1ion's Avatar
Mil1ion
Starting Problems
I consider spelling to be very important.
What if the company you work for spelled your name wrong on your pay cheque? You couldn't cash it.You would then need it to be spelled correctly.
Would spelling make a difference then?
I think people in general should try to get things right.
What is wrong with trying to have a great vocabulary & spell things correctly.
You did notice that I also provided information with my spelling correction ?
[font color=red]
[/font]
Old Jun 18, 2002 | 04:06 PM
beartracks's Avatar
beartracks
Starting Problems
[updated:LAST EDITED ON 18-Jun-02 AT 05:10 PM (EST)] Hey, I've been to Calgary and you folks are great but you spell funny. :P
Couldn't resist.
And I'd check for voltage on the solenoid when the key is in start position.
Bear Tracks
Old Jun 18, 2002 | 05:43 PM
lt dan's Avatar
lt dan
Starting Problems
I do appreciate someone correcting my spelling...I take no offense to it...I was born and raised in Georgia...48th in education out of 50 in national averages. My spelling is horrible...and I know it...thats why I put the word solenoid in " " because I knew it was misspelled. This message board does not have spell check.
I was taught by my grandaddy to take a long screwdriver and touch it to the first small post and then to the Positive battery post to start older cars and trucks. I have no idea what an "S" post is on the solenoid. Thanks for all the input. I probably have a broken wire somewhere... :-X11
I will continue to check this out.
Keep giving more suggestions.
Old Jun 18, 2002 | 09:21 PM
Big Bad 1Ton
Starting Problems
that trick works great. the small terminal that you are touching is the S terminal. this gets power from the ignition switch, and energizes the starter.
Mike W's Avatar
Mike W
Starting Problems
Your transmission shifter has a switch to keep the engine from starting unless you are in park or neutral. Take a real close look at it.
Old Jun 19, 2002 | 07:53 PM
lt dan's Avatar
lt dan
Starting Problems
Mike W..
I thought about the transmission slector switch... would that not prevent it from being jump started as I said I can do, if it was bad?
Can you advise exactly where it is located? I did have a load on it when it started acting up. I thought maybe that may have indirectly caused stress on the switch and caused my problem.
Old Jun 19, 2002 | 09:32 PM
Mike W's Avatar
Mike W
Starting Problems
Hi, the switch at least on a 72 is on the steering column before the firewall. To adjust, loosen the two switch attaching screws. Hold the gear selector lever against the neutral stop.
Move the sliding block on the switch to the neutral position. From the rear of the switch, insert a #43 drill in the pin hole. Slide the switch to permit the switch actuating lever to contact the switch sliding block (this is as clear as mud).
Tighten the two screws and remove the drill. Check for starting in only neutral and park.
By using the screwdriver from bat+ to the start terminal on the solinoid, you are just by-passing the ign switch and the wiring that goes to the S terminal. If the above procedure fails, check for a bad switch by shorting out the wires on the switch.
Old Jun 19, 2002 | 10:52 PM
390GT's Avatar
390GT
Starting Problems
Dewdzilla
1997 - 2003 F150
Jul 20, 2013 01:01 PM
86ford86
Electrical Systems/Wiring
May 11, 2013 02:59 PM
wyowagner
Sep 27, 2012 01:28 PM
twinraptor
Sep 4, 2012 05:49 PM
Fordman48858
Michigan Chapter
Nov 17, 2003 01:53 PM
